oil filter is leaking everywere
Guest chuftys2jz
Guest chuftys2jz
hi there i started my car today and the oil filter as started to skirt out everywere can they come loose or is there an oil pressure problem do ya reckon its a 2jz gte any help would be great thanks :)
They can if it's not been done up tight enough. Probably best off doing an oil change at the same time. Get a new oem filter from Toyota. A thin smear or new oil on the new filter o-ring and tighten until the seal makes contact and then anothe 1/4-1/2 turn. For oil get some semi/full synthetic 10w-30 or 10w-40
Guest chuftys2jz
thanks i did the oil and filter change recently but i havnt drove the car yet but its been ran a few times in the garage with no leaks and all of a sudden today its started peeing out everywhere :)
He said "everywhere", but is probably prone to exaggeration ;) It is sometimes possible for the old filter to leave its sealing ring stuck to the Modine unit, and the new one to then be sat on TWO sealing rings. The one against the Modine then blows out at a later stage. If it does this the filter will probably then feel loose. Worth checking. ALWAYS check the filter you remove has its sealing ring still in its groove.
Guest chuftys2jz
hi thanks i tightened it abit more today is there any other reason for making it leak out. The other day it sprayed out all over the side of my engine bay i ran it today for a hour in the garage and no leaks so far i wonder if it only comes out when its being revved hard im not sure the 2jz gte is very new to me lol thanks for the advice guys:)
Only one way to find out. Start 'er up and rev 'er 'ard! :D
When I changed my oil filter, I took the old one off, made sure the o ring was still in there, then scraped the mating area with a screwdriver (carefully) to make sure it was clean before fitting the new one :)
Guest chuftys2jz
i didnt need to take it off again i cleaned it all off before i fitted the new filter and my old filter still has the seal atached i was simply only asking if there would be any other reason why it would force oil out even if the filter was tight enough :)
