Brazil Posted May 26, 2012 Share Posted May 26, 2012 (edited) I had a Southbend Kevlar clutch fitted around 10k miles ago and recently it has started to slip on the higer gears only; When I changed the clutch I didn't replace the flywheel so my question is, could that be the cause that my clutch is slipping? What are all the different reason that would cause a clutch to slip? Has anybody had similar problem with their clutch? FYI: I noticed there is oil leak stain on the casing of the gearbox. Edited May 26, 2012 by Brazil (see edit history) Quote Link to comment Share on other sites More sharing options...
Brazil Posted May 26, 2012 Author Share Posted May 26, 2012 bump Quote Link to comment Share on other sites More sharing options...
