peter richards Posted May 25, 2012 Share Posted May 25, 2012 just a quicky please guys , when im doing a bit of surfing , it starts to make a whirring noise , then if i click off a site it stops . my connection is total pants but nothing i can do about it . but the whirring noise definitely is slowing it down even more, any ideas what it could be , before it goes into a shop ? thanks peter Link to comment Share on other sites More sharing options...
creative Posted May 25, 2012 Share Posted May 25, 2012 Cpu fan increasing as it is under load My work one goes nuts when i have alot of programs open! Link to comment Share on other sites More sharing options...
peter richards Posted May 25, 2012 Author Share Posted May 25, 2012 ok is that a big job to do ? Link to comment Share on other sites More sharing options...
Guigsy Posted May 25, 2012 Share Posted May 25, 2012 Depends Could be full of dust. In which case an air duster will clear it. Or it could be a wire or something catching the fan. Or the fan blade is broken Depending on the pc - remove the cover. Find the fan on the heatsink. And dust or replace. The fans are usualy universal Sizes and you can get them from maplin or online. But sometimes they are not. Need to look at it realy. Link to comment Share on other sites More sharing options...
Guigsy Posted May 25, 2012 Share Posted May 25, 2012 Depends Could be full of dust. In which case an air duster will clear it. Or it could be a wire or something catching the fan. Or the fan blade is broken Depending on the pc - remove the cover. Find the fan on the heatsink. And dust or replace. The fans are usualy universal Sizes and you can get them from maplin or online. But sometimes they are not. Need to look at it realy. If its a laptop it might me more of a pita. Even then an air duster into any vents you can see might clear it. Link to comment Share on other sites More sharing options...
peter richards Posted May 25, 2012 Author Share Posted May 25, 2012 ok thanks its an acer machine (stack) Link to comment Share on other sites More sharing options...
