My attempt at a wire tuck! *dyno vid*
FOSTA
  • Replies 139
Look at that! Exellent work mate, what a transformation :)
Where did you put your diagnosis box if you had one?
Thanks mate :D
It's just there in the stock location, just right of the front if the cam cover
I'm doing some work on a mk3 supra turbo at present mate. He's going to upgrade his injectors to 550s if your interested in the 440s that are coming out.
Oh cool, are they just plug and play or will I need some sort or resisters mate?
And thanks :)
Great work. :ok:
Is your engine the 2JZ GE ? but with a GTE spark plug cover?
Cheers dude.
Yeah mate, it's the 2jz-GE with TT cam covers and spark plug cover
- - - Updated - - -
Plug and play dude. There high imp same as a MKIV.
Could you ask him how much he is after mate :)
Nice work mate. Did you clock the injectors slighty? Can't see any wires going to them. Also how bad was it feeding the spark plug leads through the TT spark plug cover?
Hi mate, cheers.
Yeah I spun them round 180 degrees so you can't see the wires.
I'm using 8.5mm ht leads so alot thicker then the stock leads so it was quite hard but I recon the stock 5mm leads will slip through with ease! :)
