Worthy Posted August 6, 2005 Share Posted August 6, 2005 Hi, I had a new fuel pump fitted just over a week ago, and since then my fuel guage has been up the cute basically. It'll work for a day or two, then go off for a completely random amount of time, then come back on etc. I can't really get to the garage this week and I suspect it's just a loose connection somewhere. Where should I be looking to check for them though? Any help appreciated! Link to comment Share on other sites More sharing options...
Ian C Posted August 6, 2005 Share Posted August 6, 2005 Try the grey 5-pin plug on top of the pump cage. It's accessible under the black round plate that is under your spare wheel. It'll have been disturbed by the work and is the primary suspect -Ian Link to comment Share on other sites More sharing options...
supradibbs Posted August 6, 2005 Share Posted August 6, 2005 i have the same problem but mine is more over the shop pull the pump out and make sure the float and attaching sener is not lying in the bottom of the tank like mine is Link to comment Share on other sites More sharing options...
SEDGE Posted August 7, 2005 Share Posted August 7, 2005 Same happened with me..it was the 5 pin connector on top of the pump. Link to comment Share on other sites More sharing options...
Worthy Posted August 7, 2005 Author Share Posted August 7, 2005 Thanks fellas, I'll have a look after footy. Link to comment Share on other sites More sharing options...
