_Shane_ Posted May 23, 2012 Share Posted May 23, 2012 looking into purchasing an exhaust system for my tt which came off an n/a supra and before i buy it im wondering if it will fit ? Thanks in advance Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted May 23, 2012 Share Posted May 23, 2012 Only from the cat back mate Quote Link to comment Share on other sites More sharing options...
Noz Posted May 23, 2012 Share Posted May 23, 2012 usually NA systems use smaller diameter pipe too. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 23, 2012 Share Posted May 23, 2012 Only from the cat back mate Yes the exhaust fit is the same on the TT and NA after the 1st cat backwards. Quote Link to comment Share on other sites More sharing options...
abtin90 Posted May 23, 2012 Share Posted May 23, 2012 usually NA systems use smaller diameter pipe too. That's usually the case though the exhaust in question is a nur spec. Am I right in thinking they're the same diameter for the NA and tt? Quote Link to comment Share on other sites More sharing options...
Nic Posted May 23, 2012 Share Posted May 23, 2012 MT3020 Blitz NUR Spec R - 2JZ-GTE - 80mm main piping/114.3mm tail pipe MT3280 Blitz NUR Spec R - 2JZ-GE - 70mm main piping/114.3mm tail pipe Quote Link to comment Share on other sites More sharing options...
abtin90 Posted May 23, 2012 Share Posted May 23, 2012 MT3020 Blitz NUR Spec R - 2JZ-GTE - 80mm main piping/114.3mm tail pipe MT3280 Blitz NUR Spec R - 2JZ-GE - 70mm main piping/114.3mm tail pipe Wow didn't know there was such a big difference between the main piping of the two. Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted May 23, 2012 Share Posted May 23, 2012 1cm isn't really a big difference though mate.Wow didn't know there was such a big difference between the main piping of the two. Quote Link to comment Share on other sites More sharing options...
abtin90 Posted May 23, 2012 Share Posted May 23, 2012 1cm isn't really a big difference though mate. Probably not though I'm sure it would make a notable difference in an exhaust the same way just one or two mm could make a massive difference on a turbo Quote Link to comment Share on other sites More sharing options...
