Going Single On My Soarer
neil tt
I want to change to a single and have'nt got a great deal to spend so was looking at this manifold
http://www.ebay.co.uk/itm/280881330654?ssPageName=STRK:MEBIDX:IT&_trksid=p3984.m1952.l2649
I would like to use this turbo,
http://www.turbodynamics.co.uk/shop/8037125001s-new-genuine-gtx3071r-turbocharger-no-thousing-p-2346.html
I don't have any idea which turbo housing I need. The car already has 264 cams, and 800cc injectors,and fuel pump to match, I was looking for about 450-500 rwhp. Or any other turbos that might be better, just want something that doesn't spool to late in the rev range :)
I have just fitted that exact same manifold on mine and ive gotto say its worth every penny, very strong and fits perfect, although some of the nuts are very hard to tighten due to the pipework being close.
Turbo i used was the HX35 Turbone sold on ebay also, spools up at 2.500rpm and is on full power at 3.200 easy.
Yes its the comp RS35 and i must say its a super turbo for the money, its only around 450 as i still have the stock ECU for now, but once i save up for a good ECU then i will try and push the turbo to 550 and maybe more.
Did you see my short vids i put up on the forum when i finished the install.
