ellis Posted May 21, 2012 Share Posted May 21, 2012 Howdy I've just replaced my very dead battery with a newie and another of the small problems that raised its head obver the weekend was a very poor battery terminal. Does anyone have a recommended source for these and is it correct that I need 25mm versions? Have fitted another HCB005 from Halfords so need them to fit that. Cheers in advance. Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 21, 2012 Share Posted May 21, 2012 These guys are good and they seem to stock everything http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php Quote Link to comment Share on other sites More sharing options...
ellis Posted May 22, 2012 Author Share Posted May 22, 2012 Cheers Steve - had a ganders there. This is a pic of the positive terminal - anyone any clues as to what this one is called (style-wise)? Picked up 2 universals yesterday and the positive one is no good for mine at all! Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 22, 2012 Share Posted May 22, 2012 Are they the smaller diameter, round ones? I think you need the 'Japanese type' connectors if that's the case. I'd measure up and then give those guys a call to check. I think this is what bought for my first JSpec Supra. Refs from that website are BTJP (+ve) and BTJN (-ve). Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 22, 2012 Share Posted May 22, 2012 I've jsut noticed they also sell "Battery post collars. Use when fitting standard clamps to smaller battery posts". Dunno if that's of any help. http://www.vehicle-wiring-products.eu/VWP-onlinestore/battconns/battclamps.php Quote Link to comment Share on other sites More sharing options...
garethr Posted May 22, 2012 Share Posted May 22, 2012 Unless you replace the positive cable, I think you'll have to buy the clamp from Toyota. What's the problem - is the clamp loose on the post? Quote Link to comment Share on other sites More sharing options...
ellis Posted May 22, 2012 Author Share Posted May 22, 2012 Unless you replace the positive cable, I think you'll have to buy the clamp from Toyota. What's the problem - is the clamp loose on the post? Yep - totally fubared - it's hanging on by prayer only! Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 22, 2012 Share Posted May 22, 2012 Yep - totally fubared - it's hanging on by prayer only! Depending on how tight a stretch it is, it might be worth extending the power cables slightly. IIRC the same supplier does battery cable in whatever length you want and mahoosive insulated block-connector type things for battery cables (i.e. designed for this purpose). Of course you could just replace the connectors to work with 'UK' batteries and have a wider choice of options next time the battery needs doing. Maybe those adaptors would work in the interim? Quote Link to comment Share on other sites More sharing options...
garethr Posted May 22, 2012 Share Posted May 22, 2012 (edited) You could try removing the clamp, taking the bolt out, and running a hacksaw with two blades down the slit. ..Of course you could just replace the connectors to work with 'UK' batteries and have a wider choice of options next time the battery needs doing. Maybe those adaptors would work in the interim? The Halfords battery has "UK" terminals, doesn't it? Is the "Japanese" clamp too big or too small for UK terminals? Edited May 22, 2012 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 22, 2012 Share Posted May 22, 2012 The Halfords battery has "UK" terminals, doesn't it? Is the "Japanese" clamp too big or too small for UK terminals? The terminals on the battery that came over from Japan in my first Supra were much smaller (diameter) than regular batteries. I think Halfords sell "Japanese" style batteries and UK batteries? Quote Link to comment Share on other sites More sharing options...
ellis Posted May 22, 2012 Author Share Posted May 22, 2012 No - the clamps would fit OK, it's just that my positive clamp is self-destructing. And finding that style of clamp is proving fun. Might just pop up to Toyscrota and see what they have that's similarsame. Quote Link to comment Share on other sites More sharing options...
garethr Posted May 22, 2012 Share Posted May 22, 2012 (edited) Terminal, battery positive 90982‑05036 (05/1995 - 07/1999) 90982‑05037 (05/1993 - 04/1995) Could you make one of these work? http://www.vehicle-wiring-products.eu/VWP-onlinestore/battconns/photo/02100.jpg eBay or http://www.vehicle-wiring-products.eu/VWP-onlinestore/battconns/battclamps.php Edited May 22, 2012 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted May 22, 2012 Share Posted May 22, 2012 I just cut mine off, and recrimped the wire with a new 8mm ferrule on each then heat shrink, think mine were the universal ones from halfrauds too Quote Link to comment Share on other sites More sharing options...
Iky Posted May 23, 2012 Share Posted May 23, 2012 This is how I did mine. I cut off the stock connectors and used the original holes in them to fasten them to some new clamps I got from Halfords for a few quid. Quote Link to comment Share on other sites More sharing options...
ellis Posted May 26, 2012 Author Share Posted May 26, 2012 Ended up buying the 'proper' one from Toyota in the end - part number (just in case anybody wants/needs one as there are 2 types - one for smaller Japanese terminals, and the right one for us lot) which is: 09082-05037. Total cost (including VAT and not phoning me as promised to let me know it was in) was £20.31 - yes, I coughed as well!!! Anyway, perfect fit, job done, car lives (at least slightly until the new radiator arrives Monday - thank you Mr Wilson!) Quote Link to comment Share on other sites More sharing options...
