jake supra Posted May 20, 2012 Share Posted May 20, 2012 Hi Guys, I'm getting some knocking from the rear of the car. It makes the noise over any small or large bump or hole. I've change the suspension for coilovers but no success. Any ideas? Maybe drop links or worn out bushes. Cheers for any advice. Link to comment Share on other sites More sharing options...
JDukesy Posted May 20, 2012 Share Posted May 20, 2012 Hi Guys, I'm getting some knocking from the rear of the car. It makes the noise over any small or large bump or hole. I've change the suspension for coilovers but no success. Any ideas? Maybe drop links or worn out bushes. Cheers for any advice. I have a similar knock except on my front right. Im just about to put coilovers and new drop links on im hoping this will sort the problem. However any other suggestions as to what it might be would be good as i would like to sort it all at once. Link to comment Share on other sites More sharing options...
bodilx6 Posted May 22, 2012 Share Posted May 22, 2012 Sounds like drop links. You are sure its not the boot rubbers? The sound is from the suspension? Is it only when one wheel is going over a bump or also when both hits a bump? Link to comment Share on other sites More sharing options...
