Noz Posted May 18, 2012 Share Posted May 18, 2012 So... I needed yet another gauge, one I probably should of got when I went NA-T anyway. But we live and learn so here my AFR gauge needs a new home somewhere. The clock looks a bit naff in the pre-facelift, so thought I'd put a gauge here like many of you already do. Wanted something a bit different, so thought I'd mount the gauge slightly out of the dash, and have it turned towards the driver slightly. I think I've mounted it too far from the dash. With the gauge in the pod, it seems to sit a fair way out. I think I will sand it down to sit slightly lower. I think as it is, it might look a bit in your face due to the extra length the face of the gauge will add. After making the hole oval shaped, I had to remove the back of the pod holder. Then position the pod, easy job really. Took me about half an hour. Time consuming bit will definitely be tidying it up making the finish nice. Think I'll remove some material later, and see how it suits the dash. Quote Link to comment Share on other sites More sharing options...
Noz Posted May 20, 2012 Author Share Posted May 20, 2012 Made some progress with this. Just need to buy some more matt paint and then it's ready. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 20, 2012 Share Posted May 20, 2012 Hey mate. What is the paste your using to shape around the pipe? Quote Link to comment Share on other sites More sharing options...
Noz Posted May 20, 2012 Author Share Posted May 20, 2012 On the front ive used just standard car filler mate. It gets a bit pourus so needed to clean up the finish and fill the holes afterwards. Filler primer and some 1200 grit paper helps finish off the top sutface tillyou get a real decent finish. What you thinking of making :-) Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted May 20, 2012 Share Posted May 20, 2012 I think you should do it with all of your gauges now! Quote Link to comment Share on other sites More sharing options...
Noz Posted May 20, 2012 Author Share Posted May 20, 2012 The stock gauges? or aftermarket. cuz that would take forever. ive probably too many..but on an na-t you cant ever be too sure. your pushing limitations. maybe i should get a few more... just in case! lol Quote Link to comment Share on other sites More sharing options...
Noz Posted May 28, 2012 Author Share Posted May 28, 2012 Just an update. It's not 100%, there are a few imperfections that I'm not happy with. Probably me being over the top but hard to see them from photos so here are the ones I've taken. I'll grab the pod mounted and wired in soon enough. Will probably paint the gauge bezel if it looks out of place. Think it turned out ok. Also smoothed the sig lighter surround, looked a bit gash with the stock ring that's moulded in. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 28, 2012 Share Posted May 28, 2012 awesome work as always dude when can i book my car in , haha Quote Link to comment Share on other sites More sharing options...
lexmk4 Posted May 28, 2012 Share Posted May 28, 2012 you did it once again mate , looks awesome Quote Link to comment Share on other sites More sharing options...
ellis Posted May 28, 2012 Share Posted May 28, 2012 Hugely impressive mate - wish I could do this sort of thing! Quote Link to comment Share on other sites More sharing options...
Noz Posted May 29, 2012 Author Share Posted May 29, 2012 Thanks for a nice comments guys, I'm hoping it doesn't look OTT when it's all installed. I might do another gauge moulded in on the other side near the mirror controls and sell it just for something random to make. Quote Link to comment Share on other sites More sharing options...
Josh Posted May 29, 2012 Share Posted May 29, 2012 That looks great Quote Link to comment Share on other sites More sharing options...
pbryant_knight Posted May 29, 2012 Share Posted May 29, 2012 Looks really good mate. Nice blending with the filler. Peter Quote Link to comment Share on other sites More sharing options...
abtin90 Posted May 29, 2012 Share Posted May 29, 2012 Great work as always noz! Out of interest how many gauges do you have in your car now lol? Quote Link to comment Share on other sites More sharing options...
Noz Posted May 29, 2012 Author Share Posted May 29, 2012 Thanks guys, the finish on the filler took some time. Really enjoying getting back into making things now Uni has died down for a bit. I've got 7 when I install this one. It's a fair few, but I'd rather have that peace of mind. I'm only installing an AFR due to having fueling issues, which to be honst I should have done when I went NA-T. David P has 6 just in his upper glove box for his supercharger build. Better to have too many gauges than not enough if your ECU doesn't log as much as you want it to. Plus gives me something to build Quote Link to comment Share on other sites More sharing options...
Westy Posted May 29, 2012 Share Posted May 29, 2012 Nice work. Quote Link to comment Share on other sites More sharing options...
Noz Posted May 29, 2012 Author Share Posted May 29, 2012 Nice work. Thanks dude Fitted the gauge up today. Still seems a bit far. The fact the gloss bezel catchs reflection makes it stick out more I think. I've reduced the depth of the bezel to help lower the gauge into the dash a few mm. I've also prepared it and sprayed it with primer ready for a matt black. I think it a more suttle look will suit it better being less shouty. More progress tomorrow hopefully, get it sprayed and see how it looks. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 30, 2012 Share Posted May 30, 2012 awesome mate. Looks like the ignition bit lol Quote Link to comment Share on other sites More sharing options...
Noz Posted May 30, 2012 Author Share Posted May 30, 2012 That so true! I never even thought about that. Maybe that's where my brain got the idea from! Good spot Quote Link to comment Share on other sites More sharing options...
Noz Posted June 2, 2012 Author Share Posted June 2, 2012 (edited) This small idea has actually turned into a fair amount of faffing about to get it looking neat. Spraying the AEM gauge bezel was definitely a good idea. The gloss black finish made the whole thing look a bit gash. Having reduced the depth of the bezel, the gauge does have a slight bit of contact with the bezel threads now, so I'll need to take them back slightly as well to get a nice flush finish. It's not sat square either but that's because it's just loosely sat in the pod. Edited June 2, 2012 by Noz (see edit history) Quote Link to comment Share on other sites More sharing options...
FOSTA Posted June 2, 2012 Share Posted June 2, 2012 Looks good mate, well done Quote Link to comment Share on other sites More sharing options...
Noz Posted June 2, 2012 Author Share Posted June 2, 2012 Thanks buddy Hows your FFIM coming on? Quote Link to comment Share on other sites More sharing options...
Noz Posted June 11, 2012 Author Share Posted June 11, 2012 All fitted. Pleased with the outcome. Time to move on to the next project. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted June 11, 2012 Share Posted June 11, 2012 Looks perfect, looks like its meant to be there nice work Quote Link to comment Share on other sites More sharing options...
listy Posted June 11, 2012 Share Posted June 11, 2012 Looks smart dude Quote Link to comment Share on other sites More sharing options...
