little num Posted May 17, 2012 Share Posted May 17, 2012 Hello folks i am looking to buy an R154 box and was wondering what mk3 supra they was fitted to THANKS. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 17, 2012 Share Posted May 17, 2012 the 154 was fitted the the 7mgte cars and the later 1jzgte cars, the 7mge used an early w58. if you can get a 154 from a soerer of chaser it will be dropin fit with the shifter in correct place on thecorrect mount . if you get a mk3 box from a 1jz it will mate straight up but the mounting bracket will beed playing with and a shifter exstension is needed. a 7m box will also need a jz bell Quote Link to comment Share on other sites More sharing options...
Guest JohnSupra1 Posted May 17, 2012 Share Posted May 17, 2012 the 154 was fitted the the 7mgte cars and the later 1jzgte cars, the 7mge used an early w58. if you can get a 154 from a soerer of chaser it will be dropin fit with the shifter in correct place on thecorrect mount . if you get a mk3 box from a 1jz it will mate straight up but the mounting bracket will beed playing with and a shifter exstension is needed. a 7m box will also need a jz bell Correct and there is one forsale on ebay bidding from £100 Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted May 17, 2012 Share Posted May 17, 2012 What 'box does the 2.0 TT mk3 use? Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 18, 2012 Share Posted May 18, 2012 All mk3 turbos (latest one) use the r154 Quote Link to comment Share on other sites More sharing options...
garethr Posted May 18, 2012 Share Posted May 18, 2012 What 'box does the 2.0 TT mk3 use?W58 (W something, anyway). The 1G-GTE didn't produce enough torque to need the R gearbox. Quote Link to comment Share on other sites More sharing options...
little num Posted May 18, 2012 Author Share Posted May 18, 2012 Im going to buy that kit from france but thinking ill get a complete MK3 turbo manual and scrap the car and keep the box as a spare JUST incase i break mine. buying a box alone is too much but a whole car can be found for 500 and buy the time ive wieghted it in and scraped the alloys box should cast me £200 if that. Quote Link to comment Share on other sites More sharing options...
Guest Big T Posted December 31, 2012 Share Posted December 31, 2012 Hello guys, Sorry for bumping up an old thread but this came up in the search and thought I would reply rather than start a new thread. I have spotted a mk3 supra fitted with the R154 gearbox which I am considering buying purely for the conversion parts. Will the R154 from the MK3 (7M-GTE from a 1990) fit a MK4? If not what will it need to fit? Thanks Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted December 31, 2012 Share Posted December 31, 2012 Slam in a search bud, it's been covered a couple of times. Should be easy enough to find Quote Link to comment Share on other sites More sharing options...
Guest Big T Posted December 31, 2012 Share Posted December 31, 2012 I will do, this came up from my intitial search, Ill keep going. I am not sure if what I am reading above means that the gearbox i have found will need fiddling with the bell housing and the gear selector to get it to fit. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 31, 2012 Share Posted December 31, 2012 i guess your looking at this http://www.ebay.co.uk/itm/TOYOTA-SUPRA-7M-GTE-TURBO-SPARES-OR-REPAIRS-R154-MANUAL-GEARBOX-DRIFT-TRACK-/181052979011?pt=Automobiles_UK&hash=item2a27993743 Quote Link to comment Share on other sites More sharing options...
Guest Big T Posted December 31, 2012 Share Posted December 31, 2012 Thats right ash, it just got me thinking really but after having a search I found this... I have just cut a hole for now, this is do-able in my drift car because Im not really running any centre console round the gear stick at the moment. I have a chap in Milton Keynes that can extend anyones 154 shifter to fit the MKIV for £175, you send him your bits with a self addressed envelope with the extact measurement you want it extended by and he'll do it and post it all back for you But to re-cap you'll need: R154 gearbox R154 to 1/2j bellhousing R154 slave R154 clutch and flywheel Front half of R154 prop Rear half of 2j prop Then you'll need to get the 2 props cut and shut. You'll also need to make a new gearbox mount for the R154. Then extend the gearshift. That was from 2010, in the thread (11 pages long) it seems that not a lot of people was running the R154 in the MKIV, not sure if any there are more now nearly 3 years later. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted December 31, 2012 Share Posted December 31, 2012 loads of people run a r154 in a mkiv. little num is still with a single turbo. Quote Link to comment Share on other sites More sharing options...
listy Posted December 31, 2012 Share Posted December 31, 2012 The R154 iirc is good for around 500ftlbs torque, so a small single will be fine with it. It's what I'm looking at getting when I go single, as I'm only after 500-550hp and around 450-500ftlb torque. Plus, an R154 is pennies compared to a getrag, so I could buy a few and if one breaks, just drop another in Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted January 1, 2013 Share Posted January 1, 2013 The R154 iirc is good for around 500ftlbs torque, so a small single will be fine with it. It's what I'm looking at getting when I go single, as I'm only after 500-550hp and around 450-500ftlb torque. Plus, an R154 is pennies compared to a getrag, so I could buy a few and if one breaks, just drop another in They'll handle closer to 700hp. Quote Link to comment Share on other sites More sharing options...
listy Posted January 1, 2013 Share Posted January 1, 2013 They'll handle closer to 700hp. I thought it was torque that killed boxes? Quote Link to comment Share on other sites More sharing options...
