coza Posted May 16, 2012 Share Posted May 16, 2012 Hi I took my car to a mechanic which is still there at the moment to install my HID lights , he said that he has wired them in but there not lighting ? Has anybody got instructions or a few tips that might resolve this ? Cheers Quote Link to comment Share on other sites More sharing options...
Nic Posted May 16, 2012 Share Posted May 16, 2012 (edited) First thing to try is to reverse the positive/negative wires. If that doesn't work then it may be the voltage to the ballast packs is too low to fire up the HID bulbs. The ballasts need a minimum voltage to illuminate the bulbs, if the voltage is too low the bulbs will either flicker or not light at all. Test them by wiring them up directly to the battery, if they work connected directly to the battery but not when wired to the headlight harness then the easiest fix is to fit a relay harness (see link below). http://www.ebay.co.uk/itm/H4-Hi-Lo-HID-Bi-Xenon-Battery-Loom-Harness-Relay-Wiring-/300654383049?pt=LH_DefaultDomain_3&hash=item460065cfc9 Edited May 17, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
coza Posted May 16, 2012 Author Share Posted May 16, 2012 Okay il find out tomorrow thanks Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 16, 2012 Share Posted May 16, 2012 Jesus, let your mechanic work it out, that's what you're paying him for! They have to be connected a certain way so reverse each plug in turn and see if they work. Also give the plug onto the bulbs a good squeeze, works sometimes. Quote Link to comment Share on other sites More sharing options...
Neil1985 Posted May 16, 2012 Share Posted May 16, 2012 I got some hids and fitted them myself, but the connector pins to the ballast didnt work they way you expect them to. They had to be reversed otherwise they didnt work. But yours maybe different. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted May 16, 2012 Share Posted May 16, 2012 I got some hids and fitted them myself, but the connector pins to the ballast didnt work they way you expect them to. They had to be reversed otherwise they didnt work. But yours maybe different. As stated above you have to reverse the polarity................ Or wires.......... Or something...... He is a mechanic so you should be fine as there is only so many options. Quote Link to comment Share on other sites More sharing options...
tony tt Posted May 16, 2012 Share Posted May 16, 2012 Reversed polarity on mine and they worked fine after having the same issues. Quote Link to comment Share on other sites More sharing options...
L18msy Posted May 16, 2012 Share Posted May 16, 2012 As above. You should have fitted them yourself, they are a doddle to do. Quote Link to comment Share on other sites More sharing options...
coza Posted May 17, 2012 Author Share Posted May 17, 2012 Hi sorted it, it Was the wires that had to be switched around. Cheers Quote Link to comment Share on other sites More sharing options...
