V160 6 speed box.
JamieP
Is the job difficult to do?
Are you handy with; A welder, an angle grinder, a drill, a soldering iron and have a half decent toolkit? If so then no!
You will also need; Prop, Flywheel, Clutch, Spigot Bearing, manual gear surround, manual clocks, rubber shifter gaiters, and ofc all associated bolts. Changing the diff to the 6 speed ratio is also recommended. :). If not, buy it and bring it down to SRD, we can definitely do it :D
Wow seems not all that bad, not something I'd want to do rather the pros do it, iv done a headgasket change on a mr2 in the past and that is the line for me ;)
I do enjoy my auto atm tho thanks for the info anyway:)
