ReMap Done. Impressive Read Out :-)
a98pmalcolm
  • Replies 59
My BPU auto was dyno'ed at 316 at the wheels, so that result is very impressive.
Mine was 310 on a Dynapack hub dyno with a boost leak and leaking oil cooler
Nigels on the same day (UK spec Supra) was 425.
Regardless of figs a Dynapack hub dyno is wheel hp? and Malcolms 455.5 is wheel hp I presume?
Mine was dyno'ed on a DynoDynamics, so I have no idea if that's correct, or yours was more likely.
Nigel did get his dyno'ed at Thor Racing too and it was around 435 , not 100% what they use though but from readin on here they are accurate for readouts
Hi JellyBean no BPU Supra will be over 420 at the wheels as that would make it about 500BHP car lol..
Before Syvecs and injectors mine was 406BHP at the flywheel
Mine is 382.3 at the wheels. Its been questioned via PM and this thread what my spec is . Its all in my profile but for peoples convenience I will post here, and it hasn't been cheap :)
Engine Specifications:
HKS BOV
Big Front Mount Intercooler
NGK Grade 7 Plugs
264 9.3mm Whifbitz Road Cams
AEM Water Cooled Injection
Fuel Pulsator Bypass
Whifbitz Alloy Radiator With Whifbitz Rad Cap
Whifbitz Adjustable Pulleys
Gates Racing Uprated Blue Cambelt
Blue Vacuum Pipes
Blue Radiator Pipes
Chrome Engine Components And Dress Up
JapSpeed Strut Brace
Turbocharger & Induction:
Cone Air Filter
Stock Jap Spec Turbos
Fuel, Tuning & ECU:
Walbro Fuel Pump
650cc SARD Injectors
Syvecs S6 ECU
Toucan touchscreen display
Syvecs Advanced Traction Control With 8 Point Adjustable Knob
Exhaust:
Full HKS System
Double De-Cat
NTK L2H2 (LZA-09-E1) Wideband Lambda Sensor
Drivetrain:
Competition Clutch Lightened Flywheel
Stage 4 6 Pad Competition Clutch
Short Shifter
Edited by a98pmalcolm (see edit history)
Thats hub dyno's for you, The hub figure will be about the same as flywheel on a dyno dynamics.
