welshbuddy Posted May 13, 2012 Share Posted May 13, 2012 Hey guys, cars had a problem last 2 days, it tries to stall as I'm coming to a stop. I got to keep reviving at traffic lights to keep UT from stalling . I've done a search but there was no real awnswer. When I start the car it does have Abit of a erratic idle. Any ideas. Cheers. Quote Link to comment Share on other sites More sharing options...
Soopra Posted May 13, 2012 Share Posted May 13, 2012 Turbo or N/A? Could be an air leak... Quote Link to comment Share on other sites More sharing options...
Sukhy Posted May 13, 2012 Share Posted May 13, 2012 Idle Control Valve need cleaning? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted May 13, 2012 Share Posted May 13, 2012 Worth checking coilpack clips or plugs if you havent already Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 13, 2012 Author Share Posted May 13, 2012 sorry its a twin turbo 1jz. ill have to wait till next weekend before i can check anything , hopefully it is just something easy . Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 13, 2012 Share Posted May 13, 2012 This is usually caused by overfuelling or a stuck idle control valve. Check your oxygen sensor via the diagnostics port and clean up the ICV Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 14, 2012 Author Share Posted May 14, 2012 cheers dude, ill give the ICV a clean when i get home on saturday . Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 14, 2012 Share Posted May 14, 2012 Yep sounds like ICV is sticking. Dead easy to do mate Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 14, 2012 Author Share Posted May 14, 2012 Good Good !. Its a right pain in the ass, got me worried when it stalled on a junction lol. Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 26, 2012 Author Share Posted May 26, 2012 hey guys just bout to sort this out, what you suggest i clean it with?? cheers Quote Link to comment Share on other sites More sharing options...
SPG Posted May 26, 2012 Share Posted May 26, 2012 im sure i used Carb cleaner on mine buddy as thats what was recommended Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 26, 2012 Author Share Posted May 26, 2012 just disconnected it now mate, is it water that comes out of the pipes?? if so do i just carry on?? and drain it abit? Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 26, 2012 Author Share Posted May 26, 2012 + did you just blast the Carb cleaner through a few times? then refit?? Quote Link to comment Share on other sites More sharing options...
SPG Posted May 26, 2012 Share Posted May 26, 2012 I removed the ICV and left it to soak in the Carb cleaner over night buddy, i think gave it a good rub down with a clean dry cloth and sprayed a little more cleaner on it and fired it back in. I cant say that i remember there being any water in the pipes though buddy, hmmmmm may have to go and remove it from my project sup to confirm. Quote Link to comment Share on other sites More sharing options...
SPG Posted May 26, 2012 Share Posted May 26, 2012 I used this guide by Geo buddy, http://www.mkivsupra.net/vbb/showthread.php?210956-How-To-Clean-Idle-Control-Valve-Cleaning-Aka-ICV-(IAC) Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 26, 2012 Author Share Posted May 26, 2012 ahh ya see i didnt take mine apart, i left the top attached! lol, maybe thats why, ill go pull it off in 10 mins, need to let it cool down, cheers mate!!!! Quote Link to comment Share on other sites More sharing options...
SPG Posted May 26, 2012 Share Posted May 26, 2012 Not a problem buddy Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 26, 2012 Author Share Posted May 26, 2012 just got it out again, i Cant seem to pull mine apart, it is on the 1jz engine, its the same sort of thing just Different exit of pipe and it does'nt look like i can pull it apart :S? what do you guys suggest? Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted May 26, 2012 Author Share Posted May 26, 2012 UPdate : Doesnt rev Higher than 3-4k if i plant my foot down, will rev higher if i increase the throttle slowly, its still Stalls also .. Does that mean i need a new ICV? Quote Link to comment Share on other sites More sharing options...
