Boosting through the roof - please help
Pig
your best to go straight to the turbo pressure first of all to the bottom of the waste gate NO boost controler this is so you know for a fact what is giving you the issue,
Because at the end of the day it used to work correctly and then stopped so you now need to find that propblem and over come it accordingly.
i would want to know that the wastegate works correctly before manipulating it IMO
Ok, done as suggested. Just wastegates.
Turbo feed to bottom of wastegates.
Left the top hoses off and then blocked then off. This didn't seem to make any difference. Boosting to 1.3.
Next step is to plumb turbo feed and bottom into the IN of the boost controller and the top of the wastegates to see what happens - with b/c set on 0. I don't know how to turn it off...
hang on mate sounds like you got that slightly wrong,
just connect the bottoms to the turbo feed and leave the tops able to breath IE dont block them.(as this could allow for a resistance preasure)
and if you still make high boost that way then your wastegates might be the problem.
do you know what the wastegate spring preasure is ment to be?
Did it both ways. 1 with the tops going to atmosphere and 1 with it blocked.
With it open it boosted to 1.3 bar.
Seems odd as I thought I had a 1 bar spring. Main the being that the boost is under control.
Now it's time to start with the boost controller.
Just having tyres fitted then will be ready to find out if it is fixed or not.
(fingers crossed)
If it works then I assume there was a pipe split... If not the the bc it is.
if your making a solid 1.3 maybe the springs are 1.3 you never know,
i take it you have checked the turbo preasure reveance for leaks? it does seem high wastegate preasure
my apexi avcr can only start to control boost after 20% so would sit you around 1.6
not sure how you managed to get the boost down to 0.9 with the boost controller but even if the worst come to the worst you can just sit at the 1.3 wastegate boost
Motec do a great series of videos on wastegate control plumbing. http://www.motec.com.au and look for Webinars. Get rid of that blue silicone junk, any hose in a wastegate set up that needs tie wraps to hold it on is a disaster in the offing. use proper black rubber hose from the likes of Gates, none textile braided silicone, like most of the junk in small bore sizes is prone to splitting from the cut end, or blowing off.
Nor me. I think it will have been what I suspect was the route of the whole problem. A loose pipe.
I have now plumbed the boost controller back in and it is working perfectly! Thank you so much, not only did you both help me fix the car before the dragonball but helped me learn how the wastegates and boost controller works.
I can't explain how much I appreciate it.
Chris - thank you for this input. I did wonder when I was a halfords in the stick on Corsa crap section if I was better off just buying fuel hose.
I will have a google and get it replaced with some decent pipe as you have suggested.
Thanks
Edited by Pig (see edit history)
I wouldn't suggest it would be a worth while exercise as each car is so different.
I would need about 12 hoses of random lengths and 4 T pieces.
I am just going to get the tape measure out and order away.
Happy to order with you if you want to try and get a bulk buy discount.
I probably won't do till next year though as I have a gearbox and diff that I want to buy first.
  • 11 months later...
WOW, nearly a year gone by and I have finally ordered some gates hose :)
