ashbuster Posted May 12, 2012 Share Posted May 12, 2012 (edited) hey guys any ideas what size i have to look for for them to fit perfect in the arch like this front and rear i dont really want to use spacers unless i have to but i want some wheels to fit like they do and i could do with knowing the size so i can price some up, would be a pain if i ordered the wrong size Edited May 12, 2012 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
Style Posted May 12, 2012 Share Posted May 12, 2012 I think I've seen the bottom one on Whifbitz' site for the diffuser setup. Maybe worth a PM if they have any info? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 12, 2012 Author Share Posted May 12, 2012 ive pm'd paul mate just waiting for a reply but thought i would make a thread im guessing there 19" too Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted May 12, 2012 Share Posted May 12, 2012 19x10 ET30 rears and 19x9 et35 fronts I would have thought....with 5mm spacers in reserve! Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 12, 2012 Author Share Posted May 12, 2012 ohh i thought they were wider than that on the rear thanks bud Quote Link to comment Share on other sites More sharing options...
Nic Posted May 12, 2012 Share Posted May 12, 2012 The Ridox kit is 30mm wider at the front and 50mm at the rear Depends what width wheels you want to fit, the following widths and offsets would be flush with the wider arches. Front 9.0 +05 Rear 10.0 -15 Front 10.0 +15 Rear 11.0 -05 Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted May 12, 2012 Share Posted May 12, 2012 lol, I was being a bit conservative with the offsets then eh? haha Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 12, 2012 Author Share Posted May 12, 2012 nice one guys Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 13, 2012 Author Share Posted May 13, 2012 (edited) this is going to sound stupid but what are the + and - numbers for on the end? im guessing its from the bolt to the rear as an extra on the width gets removed from the + or - cant seem to find the right sizes Edited May 13, 2012 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
Mario Posted May 13, 2012 Share Posted May 13, 2012 The - and + indicates negative or positive off-set The offset is the distance in mm between the centre line of the wheel rim, and the line through the fixing (hub) face. You can have positive, negative or neutral offset. http://automodified.co.za/wp-content/uploads/2012/04/Wheel-offset-explained.jpg Quote Link to comment Share on other sites More sharing options...
Westy Posted May 13, 2012 Share Posted May 13, 2012 As above re offsets. Negative offset will more than likely give you a huge dish on the rear! those sizes sound super aggressive! Quote Link to comment Share on other sites More sharing options...
Supra-duper Posted May 13, 2012 Share Posted May 13, 2012 I would wait until you've got the kit fitted before you buy the wheels mate as there will always be slight variations with anything custom/after market like this. Once it's all fitted then do some measuring up. Sounds like this is going to be good! Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 13, 2012 Author Share Posted May 13, 2012 thanks for the help guys yeah i cant wait, ive chosen the colour now and priced the rest up just need to find out roughly how much wheels and tyres are going to cost Quote Link to comment Share on other sites More sharing options...
Nic Posted May 13, 2012 Share Posted May 13, 2012 (edited) The Ridox kit is 30mm wider at the front and 50mm at the rear Depends what width wheels you want to fit, the following widths and offsets would be flush with the wider arches. Front 9.0 +05 Rear 10.0 -15 Front 10.0 +15 Rear 11.0 -05 Just to explain how I worked out the offsets above, the wheel widths and offsets below would be almost flush with the stock wheel arches. Front 9" +35 Rear 10" +35 The Ridox wheel arches are Front 30mm/Rear 50mm wider than stock, so if you want the wheels to be flush with the wider arches then the wheels would need to sit 30mm further out at the front and 50mm further out at the back. Assuming the wheels are the same widths then you would need to reduce the offsets by 30mm at the front and 50mm at the rear ie. Front +35 - 30mm = +05, Rear +35 - 50mm = -15. Front 9" +05 Rear 10" -15 You can use this offset calculator to determine what offsets you will need for different wheel widths. http://www.1010tires.com/WheelOffsetCalculator.asp Edited May 13, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 13, 2012 Author Share Posted May 13, 2012 thanks for that nic very helpfull i understand it now , confused me a little at first lol Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 13, 2012 Author Share Posted May 13, 2012 any ideas on a good website that shows you different wheels and offsets and prices ive looked over a few websites and cant seel to find what i need, ive looked on driftworks too and they only have 1 wheel in that size and its nasty. i want to look over different wheels but no crazy prices just a nice set of wheels Quote Link to comment Share on other sites More sharing options...
Nic Posted May 13, 2012 Share Posted May 13, 2012 Do you know what wheels you want? This site lists a loads of wheel brands/models http://www.wheelspecs.com/default.aspx If you find a wheel you like then your best bet is to check the manufacturers website to see what sizes and offsets they are available in. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 13, 2012 Author Share Posted May 13, 2012 hi nic thanks for that link ill have a look about. i want something simular to these 2 i know im not going to get these unless my budget is around 3k-4k so i want something similar Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 13, 2012 Author Share Posted May 13, 2012 i can never find the right ones ive found a set of wheels and when i look they have 12" et20 10" et12 et35 "9.5 et12 et25 cant seem to find any with a - then another set 10" et20 9" et20 Quote Link to comment Share on other sites More sharing options...
abtin90 Posted May 13, 2012 Share Posted May 13, 2012 The Ridox kit is 30mm wider at the front and 50mm at the rear Depends what width wheels you want to fit, the following widths and offsets would be flush with the wider arches. Front 9.0 +05 Rear 10.0 -15 Front 10.0 +15 Rear 11.0 -05 In regards to the width of the arches thats what I had read too however in add heywoods thread "going full ridox" he says there not as wide as they say they are. "The arches don't actually add as much width as what they say, rears about 35mm from the standard arches (50mm on spec) and fronts about 15mm (30mm on spec)." http://mkivsupra.net/vbb/showthread.php?262113-Going-full-Ridox-(Wide-Arch)/page6 Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 13, 2012 Author Share Posted May 13, 2012 thanks for pointing that out bud, ill wait untill the kits on or trial fitted and get a measurement Quote Link to comment Share on other sites More sharing options...
abtin90 Posted May 13, 2012 Share Posted May 13, 2012 thanks for pointing that out bud, ill wait untill the kits on or trial fitted and get a measurement No prob and yeah I think thats the best option you wouldn't want to spend a fortune on wheels and then see they're not a good fitment Quote Link to comment Share on other sites More sharing options...
ashbuster Posted May 14, 2012 Author Share Posted May 14, 2012 yeah would be a very costly mistake thanks bud Quote Link to comment Share on other sites More sharing options...
