Peter P Posted May 12, 2012 Share Posted May 12, 2012 Hi Guys, Just fitted my LED rear lights and tested them. I get red rings both sides for brakes & lights, indicators & hazards are fine as well, but when I put it in reverse only getting one reverse light on the passenger side?? Is that right, or should I have 2 reverse lights?? If so, any tips on how to fix it?! Connections all look ok?! Should add the car WASN'T running at the time. I used the red disengage button and shifted it back to the reverse position. Would that matter though?! All help greatly appreciated guys! Cheers. Pete Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted May 12, 2012 Share Posted May 12, 2012 I only have one reverse light, the other side is my fog light with a red bulb. Quote Link to comment Share on other sites More sharing options...
Peter P Posted May 12, 2012 Author Share Posted May 12, 2012 I only have one reverse light, the other side is my fog light with a red bulb. Hi mate. Did wonder about that, does anyone know if the LED ones Blue Angel did are setup that way? Not an issue I guess, just looks like White LED's, not red like the others. Cheers. Quote Link to comment Share on other sites More sharing options...
