LOGIE Posted May 12, 2012 Share Posted May 12, 2012 ok so ive tracked down an engine locally to me at a breakers yard the guy says its from a supra i might go and see it on monday, what i want to know is how can i tell the difference between a supra and an aristo lump by looking at it? I know the sump is different but not easily seen. Ta Link to comment Share on other sites More sharing options...
Westy Posted May 12, 2012 Share Posted May 12, 2012 Sorry to hijack....Do they have the rest of the car mate!? Noticed your in Strathclyde also and would be good to pick up a couple of trim pieces. Link to comment Share on other sites More sharing options...
LOGIE Posted May 12, 2012 Author Share Posted May 12, 2012 dont think so mate, it was actually a mate that found it for me at a scrappy near mossend. I'll ask if you like.. what pieces you looking for? Link to comment Share on other sites More sharing options...
JakeG Posted May 12, 2012 Share Posted May 12, 2012 The sump is easy to spot mate, aristo has a forward facing one, few wires and stuff are different also but the sumps the main thing Link to comment Share on other sites More sharing options...
LOGIE Posted May 12, 2012 Author Share Posted May 12, 2012 The sump is easy to spot mate, aristo has a forward facing one, few wires and stuff are different also but the sumps the main thing from what ive been told fitting an aristo lump is a pain as a lot of parts need swapped? I thought it should have been easier to spot the difference between the two. cheers jake. Link to comment Share on other sites More sharing options...
-K1 Posted May 12, 2012 Share Posted May 12, 2012 you can easy see if it's a aristo or supra engne as the stock bov and piping are different (stock bov on aristo are screwed. on supra they are on a pipe). i got a aristo engine in my supra.. Link to comment Share on other sites More sharing options...
Swampy442 Posted May 12, 2012 Share Posted May 12, 2012 Sump is the most obvious difference. Link to comment Share on other sites More sharing options...
LOGIE Posted May 12, 2012 Author Share Posted May 12, 2012 ok so is this the Aristo sump left and supra right? Link to comment Share on other sites More sharing options...
martin p Posted May 12, 2012 Share Posted May 12, 2012 ok so is this the Aristo sump left and supra right? [ATTACH=CONFIG]151571[/ATTACH] Yep Supra is a "rear" sump set-up. Link to comment Share on other sites More sharing options...
LOGIE Posted May 12, 2012 Author Share Posted May 12, 2012 Yep Supra is a "rear" sump set-up. Thank you. This is one of those Qs i always wanted to ask... but didn't. Link to comment Share on other sites More sharing options...
