Oil Level Warning Light?
fordy_alexsupra
Yesturday my Oil Level Warning Light turned on, I pulled over, turned engine off and checked my oil level. It was on the maximum!
This morning i checked it again (after leaving the car over night) and the level is around 1mm over maximum. I drove and after 20sec the Level light came on again, so I parked side ways on a road with a hill (O/S at lowest point) and the light went out, which then when i drove off came on again shortly after.
The dip stick is giving me a wrong reading or sensor may be faulty or is there a sensor that reads oil viscosity (oil change), any ideas?
Oil is 10w-60 Mobil1 Extended Life, Changed around 2500km ago, i over filled it by 2mm above maximum level and i left it that way!
Will the supra burn oil, I get a small puff of blue smoke at start up, after a few days of no driving?
10w 60 is some pretty heavy oil for the JZ engine, you only need a 40 grade.
The level switch is just a float and they have been known to go bad, not to difficult to change. And the puff of smoke is probably going to be your valve stem seals
Next change ill change to a lighter grade and stay with fully synthetic yes?
Will the sump have to come off to get to the float?
Cheers
Ive seen loads of these level indicators start to fail now and they are big money, just rely on the dipstick, BTW my car runs 10/60 fully synthetic
Out of interest Dude, what brand do you use? I considered Castrol Edge 10W60 as I had a bit left over from my old M5, used to run my P1 and still run my RS Turbo on it as well with no probs. Just wondering. :)
I have used valvolene previously, just put Mobil 1 in
Personally i think a correctly working oil level sensor is the best thing since sliced bread, after it being the only thing that alerted me to a failed front main seal, in time to prevent engine failure due to lack of oil,Personallyy i would replace no matter what the cost, it could save your engine.
I actually ended up adding a super bright LED so that if anything similhappenedend again, i would have a chance to save the engine, i only wish more car had level sensors fitted as std, rather than just a low pressure light, by which time iusuallylly far to late.
Iv read that before on a old thread. I have a voltmeter how can I check the output on the alternator and what should the output be?
/QUOTE]
There is a procedure to check out the alterntor and voltage regulator. I'l see if I can find it and upload it.
When my alternator went, the oil level light would come on but then go out when the engine was above a certain RPM. That RPM went higher and higher pver the course of a few days until the oil light was on almost all the time, then I started to get other lights (ABS. catalyst temp) and ironically the night the alternator actually failed. the battery warning light finally came on.
Try revving your engine and see if the light goes out.
If you can upload a procedure to check out the alterntor and voltage regulator that would be great :)
I had rev'ed and raced the engine but no luck, it only goes out when I stop on a hill sideways (horizontal) :S
