Guest kinkydeviltom Posted May 9, 2012 Share Posted May 9, 2012 Hi was hoping someone has had this problem before or could point me in the right direction, ive just fixed my dry solders on my warning lights and to my relief they all worked and all went off once engine started, but after driving to work and back the engine management light came on after about 10 minutes or driving and stayed on until i got home, i then started the car straight back up and it went back off, then did excactly same today, can anyone help? Quote Link to comment Share on other sites More sharing options...
Nic Posted May 9, 2012 Share Posted May 9, 2012 The most common causes of the warning light coming on are low brake fluid, front auto spoiler removed (warning light will come on at a certain speed) and faulty/badly fitted speedo convertor/delimiter. Do a diagnostic check to see if there are any error codes stored, see guide here: http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes&highlight=code Quote Link to comment Share on other sites More sharing options...
Guest kinkydeviltom Posted May 11, 2012 Share Posted May 11, 2012 Thank you, i just did that trick looping the cable, thats a clever little trick lol, error codes 41 and 42, im just going to look them up but any advice on these would be great thanks Tom Quote Link to comment Share on other sites More sharing options...
