Very cheap DBA discs
David P
I had the cross drilled ones, won't be getting another set...front disc split from the drilled hole downwards ImageUploadedByTapatalk1336623242.903014.jpg
Probably because of all the rubbish weather, but won't be having another set. I picked up some grooved ones for 160 though from Clark amazing sale!
how do they compare to stock discs?
and did you go for the plain, grooved, cross drilled ones?
I went for the slotted ones with the kangaroo paw design (It think most of them have had that) they are still going well coming on 3 years. I had pads from chris wilson, DBA disks and goodridge hoses all at once. I was happy with the set up. Although I did go to standard cheap pads after the cones from chris wilson ran down and the DBA disks work well them too :)
I couldn't really compare stock to the DBA disks as all the brake set up was uprated so its unfair to compare ..
