fan switch back light
Rob Moch
Follow the details on how to remove the dash on my site...
http://www.trlperformance.com/dash.html
It for removing the radio but most of it is fine, just stop at the radio bit.
then you'll have to remove the AC controller unit which is just a case of a few screws and pulling of the rotary konbs off (no jokes please)
Then behind each rotary knob is a small bulb which is bayonet fitted so just unscrew (90degree turn) and replace.
Most of the fiddly work is getting the dash off and to the AC control unit. Changing the bulb is easy after that.
(Not sure if you have to dismantle the AC control unit or not, I don't think so. Been a while since I looked at it to be honest)
Regards
Pete
