NOODLE Posted May 8, 2012 Share Posted May 8, 2012 after starting my car this morning my car sounded like it was farting bubbles under the dash so i turned it off straight away i spoke to a mechanic and i described what was wrong to him he advised me to call the AA as it would do damage to drive it. the AA guy did a head gasket test and the chemical he used turned green confirming that there was exhaust gases in the cooling system. he then told me that he used to work at a Toyota specialist when he was younger and had seen NA supra's blow there gaskets a lot. whether this is true or not im not sure but he told me that "after 70,000miles the head gasket would go" and then said mine could well be on the second gasket already. is there any proof of what this guy is saying because im unsure and if its true then im unsure whether to change the gasket or change the engine to a younger one. any ideas any help would be great :-) Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted May 8, 2012 Share Posted May 8, 2012 The Mark 3's suffer from headgasket issues, notoriously so! The Mark 4's however do not, 2JZ's are stupendously reliable if looked after, the fact that yours has gone after relatively little miles suggest it hasn't been cared for be a previous owner. Quote Link to comment Share on other sites More sharing options...
NOODLE Posted May 8, 2012 Author Share Posted May 8, 2012 The Mark 3's suffer from headgasket issues, notoriously so! The Mark 4's however do not, 2JZ's are stupendously reliable if looked after, the fact that yours has gone after relatively little miles suggest it hasn't been cared for be a previous owner. cheers for that, im just hoping that once done nothing else creeps up if the previous owner was carless with the cars services Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted May 8, 2012 Share Posted May 8, 2012 You will have to have the head skimmed when the gasket is done, they are 99% of the time not flat. It's also worth getting the garage to flush the coolant system properly at the same time. Quote Link to comment Share on other sites More sharing options...
SilentAgro Posted May 8, 2012 Share Posted May 8, 2012 It would probably be cheaper to change the whole engine. Quote Link to comment Share on other sites More sharing options...
NOODLE Posted May 8, 2012 Author Share Posted May 8, 2012 ye the mechanic i use is pretty good, hes pricing up a water pump cam belt etc as well ive already given him the do's and dont's list for my car Quote Link to comment Share on other sites More sharing options...
Mr Cull Posted May 8, 2012 Share Posted May 8, 2012 Possibly air in the system?? Not uncommon problem. http://www.mkivsupra.net/vbb/showthread.php?229009-Waterfall-noise-behind-dash/page2 http://www.mkivsupra.net/vbb/showthread.php?104635-Heater-Matrix-I-can-hear-the-water!&highlight=gurgling+dash Quote Link to comment Share on other sites More sharing options...
NOODLE Posted May 8, 2012 Author Share Posted May 8, 2012 no definitely head gasket its being pressurized by the exhaust gases and throwing the water out of the overflow pipe. plus the AA guy checked for exhaust gases before agreeing to take my car home Quote Link to comment Share on other sites More sharing options...
NOODLE Posted May 8, 2012 Author Share Posted May 8, 2012 It would probably be cheaper to change the whole engine. i have contemplated that to be honest a vvti lump would be nice if one comes up at the right price ;-) Quote Link to comment Share on other sites More sharing options...
RA28 Posted May 8, 2012 Share Posted May 8, 2012 (edited) This could be an interesting solution http://www.ebay.co.uk/itm/140746205261?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 http://www.ebay.co.uk/itm/LEXUS-GS300-3-0-VVTI-2JZ-ENGINE-1998-2005-/220914589515?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item336f891f4b Edited May 8, 2012 by RA28 (see edit history) Quote Link to comment Share on other sites More sharing options...
Colin-mkiv Posted May 8, 2012 Share Posted May 8, 2012 My rad was pressurising up and forcing coolant out of the overflow/expansion bottle, I fitted a new rad cap and it's not doing it any more and the temps stay just below midway on the guage. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 9, 2012 Share Posted May 9, 2012 When i blew my HG it was torn between the cylinder and the water jacket causing an overpressure in the coolant, pissed coolany out the overflow tank aswell, just make sure and check your rad after you've build it all back up as mine had cracked down the side of the rad cap neck due to pressure. It was weeping untill one day I was fault finding something else and it split good & proper and it looked like a fountain of coolant landing all over my throttle body and intake. Quote Link to comment Share on other sites More sharing options...
NOODLE Posted May 9, 2012 Author Share Posted May 9, 2012 When i blew my HG it was torn between the cylinder and the water jacket causing an overpressure in the coolant, pissed coolany out the overflow tank aswell, just make sure and check your rad after you've build it all back up as mine had cracked down the side of the rad cap neck due to pressure. It was weeping untill one day I was fault finding something else and it split good & proper and it looked like a fountain of coolant landing all over my throttle body and intake. ok il check that im just hoping my heater matrix hasnt split, thats where i heard the air in the water noise behind the dash so it did sound like it was pressurizing there first. so is this a common problem with the sz's? Quote Link to comment Share on other sites More sharing options...
Josh Posted May 9, 2012 Share Posted May 9, 2012 ok il check that im just hoping my heater matrix hasnt split, thats where i heard the air in the water noise behind the dash so it did sound like it was pressurizing there first. so is this a common problem with the sz's? The heater matrix is known to go after time. Check the carpet in the passenger footwell to see if it's wet. Quote Link to comment Share on other sites More sharing options...
NOODLE Posted May 9, 2012 Author Share Posted May 9, 2012 The heater matrix is known to go after time. Check the carpet in the passenger footwell to see if it's wet. ye i did have a look no damp in the footwell so hopefully its all good Quote Link to comment Share on other sites More sharing options...
NOODLE Posted May 14, 2012 Author Share Posted May 14, 2012 should be gettin the car back this weekend with a new veilside bumper water pump cambelt and head gasket all done :-) ANYONE KNOW OF ANY SIDESKIRTS AND REAR SPATS FOR SALE? Quote Link to comment Share on other sites More sharing options...
