Rattle from OEM Dual mass Flywheel
Samurai 20V
Hi all.
I had the clutch changed on my BPU TT6 recently, I fitted the single plate TRD clutch and pressure plate(incl release bearing)
When I changed it the shop said the flywheel is fine, but it has started to develop a rattle. It is mainly on idle, if you press the clutch then the noise disappears..
The gearchange is also getting a bit clunky, especially when cold..
I assume it is the flywheel as it is the only item that was not changed..
Should I just leave it be? Will it effect the car in any way?
If I change should I change the clutch plate as well or should I keep the current one (only has abt 5000kms on it)..
Thanks in advance.
