VVTi igniter picture.
Ibrar Jabbar
http://i224.photobucket.com/albums/dd108/wilbo666/final35.jpg
There you are ;)
P.S. Good idea to add this to the FAQ :)
P.P.S. Done, here is the table:
No code has to be inserted here.
Thats perfect, Thank you Sir. :thumbs:
I've got an igniter if you need one ibrar, I'm only down the road too
I have the igniter already, just needed the pinouts. Thanks.
I could get you a close up later today if no one else does so before then.:thumbs:
Sorted now thank you all :thumbs:
What colors do you have on your wiring? And which VVTi 2 pin plug are you talking about? The ignition condenser next to the igniter? If you are after the ignition condenser:
Pin1 - Brown - GND
Pin2 - Black-White - Grey footwell connector Pin 1 (12V Ignition)
Edited by EMPEROR (see edit history)
Here's a pic of the wiring for the igniter. I have 8 wires in total.
http://mkivsupra.net/vbb/attachment.php?attachmentid=151688&d=1337032131
Red/white
Yellowish Green
Black/White
Green
Brown
Yellow
Blue/Yellow
Pink.
Here's a pic of the plug for the VVTi, just need to know which way round the wires should be.
http://mkivsupra.net/vbb/attachment.php?attachmentid=151689&d=1337032131
Brown/Blk
Brown/red
Edited by Ibrar Jabbar (see edit history)
Mate, this is just not a Supra wiring harness... I am pretty sure you have Aristo reworked one...
VVTi solenoid wires are:
Pin 1 - White-Red - ECU D18
Pin 2 - Yellow-Black - ECU D17
Your colors doesn't match at all, so just unplug connector D from the ECU and trace pin 18 and 17...
So is for the igniter. You have to trace which color goes where in the ECU as I gave you the pins above.
There you are the ECU pinout:
http://www.2jzgarage.com/wp-content/uploads/2012/01/Supra_2JZGTE_VVTi_ECU_Pinouts.pdf
Ibrar there is a few pics in Pauls strut brace thread which clearly show the colours. Saying that I am zooming in on my iPhone, but hopefully will help you.
I did spot it earlier, even with 400% zoom it's difficult to tell the colours as they are not close up.
According to Paul's pic wires are as follow:
1. Blue/Yellow
2. Yellow
3. Brown
4. Red-Yellow
5. Pink
6. Yellowish Green
7. Red/white
8. N/A
9. Black/White
10. Green
With only difference Pin 5 being Pink instead of Green (it's the same wire coming from ECU D13 pin), but still you are missing the Red-Yellow wire mate (coming from ECU D25 pin), that's for sure! Check if it's not cut somewhere back in the harness...
As for the VVTi Solenoid they are:
I have genuine Supra VVTi wiring. So you just have to trace them back to the pins of the ECU.
1. Blue/Yellow
2. Yellow
3. Brown
4. Red-Yellow
5. Pink
6. Yellowish Green
7. Red/white
8. N/A
9. Black/White
10. Green
Just checked with Hodge and apperantly the Syvecs don't need the IGF wire so it has been eliminated. Thanks for your help :thumbs:
