turbo oil feed
Guest lancemccoo
Guest lancemccoo
hey guys im just single turboing my na but im jst looking at the oil feeds im welding a return into the sump but for the feed i was going to come off a oil sandwich plate but feel it will be better coming off from the standeard place for a turbo. i read an artical that said that there is a bolt to remove on the side of the engine and put an out feed onto it but im not sure were to take it off so just woundered if you guys could help
heres a pics of were i think it needs to come from ......
please tell me if im wrong or if it isnt possible to come off this side of the engine or will i need to come off an oil sandwich plate.
cheers, lance
To the right and a bit down of the casting you circled is one of the returns, you oil feed will come from the front of the engine, by the oil pump. The pic below shows you the general location. As you can see on my engine, theres a bolt in the rear oil drain.
cheers, lance
I'm pretty sure the bit circled is the COOLANT drain bolt, not anything to do with the oil ways...........
I think N/A-Ts usually use the oil filter housing bolt for the turbo oil feed. You can either drill and tap the existing bolt for a connector, or use the bolt from a Lexus GS300 (VVTi) or IS300 (part number 90401‑19008), which is ready to use because it's already tapped for an oil pressure switch. Search the forum for lexus union bolt
http://www.mkiv.com/techarticles/oil_sensor_mod/index.html
http://www.mkivsupra.net/vbb/showthread.php?258145-Na-t-build
Edited by garethr (see edit history)
Guest lancemccoo
cheers mate that thread was ace and also helped alot cheers :)
Guest lancemccoo
yea its coolant cheers for the heads up mate
Guest lancemccoo
http://i76.photobucket.com/albums/j40/Swampy29/Do%20Luck/eng4-1.jpg
cheers for the advice mate think the na must me a bid different to the turbo asto oilways
