sdistc Posted May 6, 2012 Share Posted May 6, 2012 Since converting my car to the Syvecs S6, I no longer need my set of excellent condition Defi Link White Face gauges, complete with Link2 module and associated daisy chain cables. Included are oil pressure, oil temperature, and water temperature gauges, which come in removable plastic buckets including "regular position" bezel. When unpacking the gauges to clean and photograph, I noticed the only minor issue - one daisy chain connector has come off the wiring, a problem very easily fixed. Features: * A bright transparent green gauge dial and a red instrument needle pointer are used in the gauges to increase visibility at night and in low-light conditions. * Memory play function: Driving data is stored into the memory at the gauge and can be replayed up to 3 minutes. * Double Warning function: A warning value can be set. When this value is exceeded, a red warning LED comes on and a beep. * Peak memory function: The gauges record the maximum vehicle speed in memory, for later review. * Differential pressure between fuel pressure and turbo can be shown if both of fuel pressure meter and turbo meter are installed. http://www.defi-shop.com/products/end/dl_meter/summary_dlm/ http://www.defi-shop.com/products/end/unit2/summary_unit2/ Given the almost perfect condition, I am after £220 + postage, ono. Link to comment Share on other sites More sharing options...
add heywood Posted May 6, 2012 Share Posted May 6, 2012 pm trdsupra he was after a set of defi's Link to comment Share on other sites More sharing options...
Carbon_Bullet Posted May 7, 2012 Share Posted May 7, 2012 pm trdsupra he was after a set of defi's none of these ones though , ETG an REV think mine are the older ones too Link to comment Share on other sites More sharing options...
Ricky49 Posted May 7, 2012 Share Posted May 7, 2012 Jamie P is after some gauges Link to comment Share on other sites More sharing options...
JamieP Posted May 7, 2012 Share Posted May 7, 2012 Jamie P is after some gauges I am but no sensors with these. Link to comment Share on other sites More sharing options...
sdistc Posted May 7, 2012 Author Share Posted May 7, 2012 Thanks for the help, guys. After talking with Jamie, I will check to see if I will have any sensors for these. Link to comment Share on other sites More sharing options...
sdistc Posted May 12, 2012 Author Share Posted May 12, 2012 Bump. Link to comment Share on other sites More sharing options...
sdistc Posted May 26, 2012 Author Share Posted May 26, 2012 Bump. Link to comment Share on other sites More sharing options...
Bossco Posted May 29, 2012 Share Posted May 29, 2012 Do you have the sensors dude? I've got a mate intrested in these. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 29, 2012 Share Posted May 29, 2012 Are you willing to split? Link to comment Share on other sites More sharing options...
sdistc Posted May 29, 2012 Author Share Posted May 29, 2012 Prefer not to split unless I get multiple buyers who will take the lot in combination. Link to comment Share on other sites More sharing options...
robby a Posted May 30, 2012 Share Posted May 30, 2012 Do you have the sensors dude? I've got a mate intrested in these. Any news on the sensors mate? Very interested if u have them Link to comment Share on other sites More sharing options...
sdistc Posted May 30, 2012 Author Share Posted May 30, 2012 Any news on the sensors mate? Very interested if u have them Mate, I haven't had time to even look at the car this week. I will try to check it out over the long weekend. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted May 31, 2012 Share Posted May 31, 2012 How much would you want for the gauges individually? I already have the controller. I'm interested in the oil pressure gauge. and a link cable. Link to comment Share on other sites More sharing options...
sdistc Posted May 31, 2012 Author Share Posted May 31, 2012 How much would you want for the gauges individually? I already have the controller. I'm interested in the oil pressure gauge. and a link cable. As I mentioned before, if you can find other buyers willing to purchase the gauges and controller you're not interested in, I'm happy to split them. Otherwise, I think it's reasonable that someone might want the all same monitoring that I did, pre-Syvecs. Link to comment Share on other sites More sharing options...
