sideexitsupra Posted May 6, 2012 Share Posted May 6, 2012 This is probably a hydraulic issue. The fluid had been just below minimum for a while, ahem blushes with embarrassment, but all had been fine. In normal driving it is ok, maybe a little spongy, but the problem is low speed. In traffic or when putting the car into the garage I can end up with the clutch pedal on the floor and have to knock the car out of gear. After hooking the pedal back up it will be fine for a bit. What's peoples opinions? Master cylinder, slave cylinder or the pipe between them. No obvious leaks and the level is still the same, right on max. It's a jspec TT6 with stock clutch and flywheel the only difference to stock is a TRD tranny mount, but can't see that having anything to do with it. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 6, 2012 Share Posted May 6, 2012 Sounds like a slave cylinder issue to me. My one went on friday... Quote Link to comment Share on other sites More sharing options...
David P Posted May 6, 2012 Share Posted May 6, 2012 Find the leak and you have found the problem. Quote Link to comment Share on other sites More sharing options...
