HELP HELP Supra won't start
Guest Evo TME
Guest Evo TME
hi,
i just bought me a twin turbo MKIV supra and took the car to have an oil change and the idiot mechanic put way too much oil in the engine (about twice the max level on the dipstick). the car was running fine from the garage to my home and then it just didnt start again. the engine turns fine but no spark at all. I have already drained the excess oil to the dipstick's max level and still nothing, i will check the sparks today to make sure they are not covered in oil, any other suggestions???
Guest Evo TME
Are you sure its no spark? Could be no fuel? Things to check, fuel pump working, EFI fuses, coil pack clips.
i checked the fuel pump and it was working fine, all fuses have been checked too and all are fine, only need to check the sparks today...hopefully they are the issue...any other thing to check??
Guest Evo TME
going by his name maybe he has an evo6 tm edition too ;)
actually i do....
Evo 6 Tommi Makinen Eidtion and US Spec Supra TT (unfortunately not running currently :()
will post pics if i can get the beast to start
btw i already got spare sparks plus yes the location is kind of an issue
Guest Evo TME
i have removed the old plugs and surprisingly there was no oil on them...i took out all the oil from the engine will leave it overnight with the drain plug open to get all the oil out...hopefully tomorrow il get a chance to put some fresh oil and plugs and the thing will start
Guest Evo TME
I can promise you the oil isn't the issue. Igniter units do just suddenly go, could be that, is it auto or manual?
6 speed manual
while were talking about the possibility of the igniter being the problem i will do a spark test tomorrow before i put the new oil and sparks on..... any idea if a JDM igniter would work on my US spec supra???
Edited by Evo TME (see edit history)
Guest Evo TME
i just talked to the SupraStore.com guys and they confirmed that the jdm and US spec ignitors are the same....i tried my brother's jdm igniter and still the car didn't start...any other recommendations as this issue is starting to piss me off
Guest Evo TME
good news i finally found out what the issue is.....the fuel pump connections were creating a short circuit for some reason and while trying to fix it last night it ended up with the fuel pump completely dying...any way i need to buy a new fuel pump and im thinking about upgrading to something better...any recommendations??? walbro??? denso???
Depends on the build spec, walbro is the usual choice for BPU power. Glad you got it sorted :)
