Guest Jute Posted May 6, 2012 Share Posted May 6, 2012 Do you guys know Sard 800 high impedance injectors (bolt on jdm 2jz-gte) dead times on different voltages? Thanks Quote Link to comment Share on other sites More sharing options...
Yakky Posted May 6, 2012 Share Posted May 6, 2012 Dead time? or you mean lag time? The dead time is usually considered part of the duty cycle even though it isn't really. But the energise time is the lag in most ECU settings, Greddy etc. I see it's 1.6ms - so quite high annoyingly for the energise time. But I can't see why the deadtime (when injectors goes off) would vary with voltage.. anyone know different? http://www.sard.co.jp/after_eng/products/engine/injector/injector_syasyu.html Quote Link to comment Share on other sites More sharing options...
Guest Jute Posted May 6, 2012 Share Posted May 6, 2012 Vipec needs to know these values: Quote Link to comment Share on other sites More sharing options...
Marc Knoll Posted May 6, 2012 Share Posted May 6, 2012 There a more 800cc Injectors from Sard 800cc SIDE Low 2 Dark Blue Oval 0.75msec 63517 800cc SIDE High 2 Brown Oval 1.60msec 63564 800cc TOP High 2 Purple Oval 1.60msec 63565 800cc TOP Low 2 Yellow green Oval 1.10msec 63566 The Lag Time is at 12V Grettings Marc Quote Link to comment Share on other sites More sharing options...
Guest Jute Posted May 6, 2012 Share Posted May 6, 2012 Thank you Marc. Still need to know value for other voltages.. Injectors part number is 63564 Quote Link to comment Share on other sites More sharing options...
Yakky Posted May 6, 2012 Share Posted May 6, 2012 Is this for piggyback? or full ECU? Quote Link to comment Share on other sites More sharing options...
Guest Jute Posted May 7, 2012 Share Posted May 7, 2012 Is this for piggyback? or full ECU? Full ecu. New Plugin Vipec. Quote Link to comment Share on other sites More sharing options...
Marc Knoll Posted May 7, 2012 Share Posted May 7, 2012 Hello Jute here is the Lagtime Table for your Injectors . 6V 2,5ms 7V 2,5ms 8V 2,4ms 9V 2,1ms 10V 1,8ms 11V 1,7ms 12V 1,6ms 13V 1,5ms 14V 1,4ms 15V 1,3ms 16V 1,2ms Grettings Marc (http://www.provotekk.de) Quote Link to comment Share on other sites More sharing options...
Guest Jute Posted May 7, 2012 Share Posted May 7, 2012 Hello Jute here is the Lagtime Table for your Injectors . 6V 2,5ms 7V 2,5ms 8V 2,4ms 9V 2,1ms 10V 1,8ms 11V 1,7ms 12V 1,6ms 13V 1,5ms 14V 1,4ms 15V 1,3ms 16V 1,2ms Grettings Marc (http://www.provotekk.de) Thanks again! Quote Link to comment Share on other sites More sharing options...
Kristian_Wraae Posted September 24, 2012 Share Posted September 24, 2012 What is the stock 440 CC lag time? Quote Link to comment Share on other sites More sharing options...
