6 Speed Flywheel, Clutch Pressure Plate with Hub & Release Bearing Plus Friction Disc
SteveC
Provisionally sold.
Only taken off my car quite recently due to noticing the clutch just starting to slip whilst at high boost in fifth whilst accelerating up a hill.
The clutch/flywheel was working perfectly prior to upping the boost with no odd noises, rattling etc.
If I'd dropped the box first and checked the flywheel, then I would not have bought a new one! Mr T's unit price for the flywheel alone is £398.89 + VAT.
The flywheel easily passed Toyota's flywheel test for wear (Rotational freeplay).
The clutch pressure plate has the hub/release bearing/washers/circlips etc still attached as a complete unit.
I can sum up by saying that the brand new flywheel and clutch (Centerforce) feels, works and sounds no different at all to the parts I've just taken off.
Ideal for an auto to manual conversion - but personally I'd definitely replace the friction disc with a brand new one.
Offers via PM.
[ATTACH=CONFIG]151110[/ATTACH]
[ATTACH=CONFIG]151111[/ATTACH]
[ATTACH=CONFIG]151112[/ATTACH]
[ATTACH=CONFIG]151113[/ATTACH]
[ATTACH=CONFIG]151114[/ATTACH]
[ATTACH=CONFIG]151115[/ATTACH]
Thanks.
how much you are looking after for everything ?
I didn't have an exact price in mind, so as per the first post, I just thought that anyone who was interested could PM me an offer for parts, or for the lot.
The friction disc should ideally be replaced with new, but the rest is perfectly usable as it is.
If you have an idea of price for the lot, just PM me ;) I have to check my July budget...
