WIFI key visible in Windows7
Branners
We run a lot of internet stations at work and to avoid changing the WIFI key each month we have a permanent WIFI key running which is put in to the internet stations and then we run Deep Freeze to stop the clients tiddling about with them.
However, I realised yesterday that if a client goes in to the network config for the WIFI you can make the WIFI code display the characters. So our super duper never to expire code is now visible to anybody who cares to look.
Has anybody worked out a way of stopping this code from being visible?
Microsoft have said it is a 'security feature', but everybody else says its a security hole for any company that wants devices on their network without them knowing what the wifi key was.
That would be ideal if we didnt have 300 different clients in each of the 11 venues every day, half of which require a wifi key and require it right there and then. The normal keys are rotating every month which is hard enough to manage, so anything more complex would just fall apart. We also have VLAN specific keys off the same SSID so managing that whole lot is a full time job. There are 2 of us in IT running venues capable of handling upwards of 600 people in some cases.
So simplicity is they key.
If there's no fix such as disabling the whole wifi settings page then I will just go back to using the monthly key and get the venue to rotate as required.
Thanks Daman,
That was one of my thoughts. We have around 10 internet PCs and about 10 laptops per venue so it would be 220 MAC addresses. Not impossible to manage but as we turn over laptops quite quickly it might take a bit of managing.
I will see if I can just disable the wifi setup via a GP and then they cannot change it or connect to a different wifi network.
