AMG Posted May 11, 2012 Author Share Posted May 11, 2012 If it i has bad a bad ECU ground, effectively no power, would any of the dash inducator lights illuminate? Or is there anything else that would point towards it being bad grounds? Where is the ECU grounded? or is it a case of following the wire from the ECU to find it? Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 11, 2012 Share Posted May 11, 2012 Get it over here and I'll sort it Link to comment Share on other sites More sharing options...
Ian C Posted May 11, 2012 Share Posted May 11, 2012 Ground faults tend to behave oddly, like dash lights lighting up dimly and there being odd small voltages on lines that should be a ground. There are a fair few ground points, you can manually check them all or you can get multimetering to try and narrow it down. I'd start with the earth on the lower part of the intake manifold, that one's not readily visible and can cause starting failures. Link to comment Share on other sites More sharing options...
TopgunTT Posted May 18, 2012 Share Posted May 18, 2012 Take up the offer by Chris if you can get it over to him? Link to comment Share on other sites More sharing options...
fordy_alexsupra Posted May 18, 2012 Share Posted May 18, 2012 loose ecu connection plugs, they all have to be fully pushed in to make connection Link to comment Share on other sites More sharing options...
