Engine sensors + factors effecting MPG
TubbyTwo
Hi all ,
Been searching and cant find a specific post, thought it might be an idea to complile a thread relating to engine sensors with part numbers and other factors that effect MPG. (Before anyone says it, I know you dont buy a supra for MPG). Mine seems to be on the low side as in less than 20mpg, obvious one is the o2 sensor, chances are on most peoples car its the original one but I think a list of things to check/replace along with the part number would be a good idea.
If anyone can contribute to this please do
-Engine-component-locations
Engine sensors (please change if incorrect)
- ECU error code check: Checking ECU diagnostic codes
- O2 sensor P/N - How-to-Clean-O2-sensors-in-NA
- Cold start sensor/ECU Coolant temp sensor??
- air intake temp sensor?
- 2JZ-sensor-resistance guide
Engine/ignition/fuel system:
- Spark plugs - FAQ-Spark-plugs
- Coil packs/coil pack clips How-To-Refurbish-coil-pack-connectors
- fuel filter??
- IAC valve - How-To-Clean-Idle-Control-Valve-Cleaning-Aka-ICV
Wheels & tyres/chassis:
- Tyre pressures
- geometry setup
- binding/seized brakes Refurbing-J-Spec-Brakes
Any more suggestions or part numbers?
Edited by TubbyTwo (see edit history)
- Spark plugs
- fuel filter??
- IAC valve -
- Tyre pressures
- geometry setup
20st+ mate in the car! and/or 10st ice setup.
Big gay wings, fitted at wrong angle (air brake):D sorry couldn't resist.:p
Edited by Tricky-Ricky (see edit history)
This is a great idea i must say tubby with the links to instruction threads etc, i was talking about someone doing the same kind of think for people wanting to go NA-T with like a list of stuff you need, costs, links to garage's etc where people can do it, links to parts etc
