Servicing a TT autobox
LOGIE
Whats all needed to service an autobox? As far as im aware i'll need: 2 crank seals, 1 filter, Sump sealant and new auto transmition fluid (ATF) is this correct? I did do a search for a guide on how to do it but to no avail.. Any help would be appreciated.
What do you need crank seals for ?
I dont think other than changing the filter in the sump and filling with new Type IV ATF
there is anything else to do.
Obviously you drop the sump and be very carefull not to get any of the old sealer inside the box, i used
brake cleaner and very carefully used a flat scraper to remove the old sealer.
Be carefull not to apply too much when you re fit the sump.
You dont want it squeezing out inside the box when you tighten the sump bolts
