J spec front pads. Taking to Japfest £20 special offer.
jake supra
Hi All,
Few Part for sale,
First Yellow Bilsteins with tein lowering springs. There are no knocks or leaks that im aware of. Done around 60k miles some surface rust. Looking for £120 posted. SOLD
N/A Rad taken off car covered 90k. £30 posted. SOLD
Front j spec brake pads around over half of pads left. £25 posted.
Blitz rad cap. £7 posted SOLD
[ATTACH=CONFIG]150975[/ATTACH] [ATTACH=CONFIG]150976[/ATTACH]
[ATTACH=CONFIG]150977[/ATTACH] [ATTACH=CONFIG]150978[/ATTACH]
[ATTACH=CONFIG]150979[/ATTACH]
[ATTACH=CONFIG]150973[/ATTACH] [ATTACH=CONFIG]150974[/ATTACH]
Thanks for looking. Jake
How much do the Tein springs lower over stock? Are they for TT or NA and would you split them from the shocks?
Do you know if they're the same as these? http://www.camskill.co.uk/m14b218s1752p7003/TEIN_S_TECH_LOWERING_SPRING_KITS_-_SUPRA_93-01_Turbo_-36mm_Front_-42mm_Rear_Toyota_SUPRA_93-01_JZA80_TURBO
Cheers.
I'm not sure on how low they will drop a TT. Had them on my N/A which due to lighter engine only gave a slightly lower than stock stance at the front. I would recommend them for a TT tho. Edit they where originally from A TT IIRC.
Not looking to split sorry.
Cheers
I know you just said you are not looking to split but if Josh wanted the springs the bit i really want is the shocks anyway so that could work?
If there is no interest in the coming weeks ill let you know if i decide to split.
