navtrd Posted May 2, 2012 Share Posted May 2, 2012 Hi im changing my tail lights to 1998 spec iv removed my old ones out no problem just a screw and a nut however i cant seem to remove the boot plastic in order to get to the wiring loom, the boot plastic im refering to is the one were the aerotop roof sits on to i have enclosed a pic. Does this plastic just pull out or is there screws hidden i cant seem to find any? Quote Link to comment Share on other sites More sharing options...
matthewm1965 Posted May 3, 2012 Share Posted May 3, 2012 There should be a couple of screws holding each aero clip in place. Then a few screws behind blanking cover dics that hold the plastic trim. Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted May 3, 2012 Share Posted May 3, 2012 As above mate, carefully unclip the cover on the bracket, be careful as they have a habit of snapping, and there are 2 bolts under each, and hey presto it's off! Quote Link to comment Share on other sites More sharing options...
navtrd Posted May 11, 2012 Author Share Posted May 11, 2012 Thanks for the help guys I managed to locate the screws under the clips thanks for the help appreciated. Quote Link to comment Share on other sites More sharing options...
