Lightened Flywheel on 6speed BPU
monsween
After a bit of advice.
My stock clutch is on it's last legs, used to slip only in 5th and it's now slipping in 3rd. So i'll be getting a new clutch soon.
I was planning on going with an uprated CW clutch and stock flywheel.
Is there any massive benefit from going with a lightened flywheel / uprated clutch. Or lightened flywheel / CW clutch. Bear in mind I have no plans of going further than BPU
Or
Will it just bug the living daylights out of me because it's noisey and heavy?
The reason i was thinking CW clutch is that it's meant to be the closest thing to an uprated stock feel clutch out there.
And as you mentioned the lightened flywheel to aid spoolup.
My next question i suppose is what lightened flyhweel.
Easy one to answer that one, Competition Clutch flywheel http://whifbitzperformancetuning.co.uk/toyota-supra-clutches-flywheels-competition-clutch-p-12151.html I can give you a 10% discount on this to.
In stock if needed.
Thanks
Paul
when i went from stock to southbend it made my life hell with the car, the chatter from it drove me insane. Its the one thing i hated about the car. So make sure if you change it and are not planning going big power then its Stock all the way for me. :D
