Guest stubo sz Posted May 1, 2012 Share Posted May 1, 2012 what is the sensor after the first cat is it a lamba or somthing else as i have a slight blow coming from there coz there is two on my manifold Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 1, 2012 Share Posted May 1, 2012 No2 cat over heat sensor Quote Link to comment Share on other sites More sharing options...
Guest stubo sz Posted May 1, 2012 Share Posted May 1, 2012 thanks for were is the best place to get a new one Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 1, 2012 Share Posted May 1, 2012 (edited) if it it same thing im talking about its not needed, it would help if you put what car you have tt, n/a, jspec,auto, i know if i had a blow in any of my cats they would be in the bin and a decat pipe in place and bpu it Edited May 1, 2012 by mellonman (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted May 1, 2012 Share Posted May 1, 2012 thanks for were is the best place to get a new one The cat heat sensors usually just get removed and the hole blocked up as they are just there to illuminate the warning light on the dash if the catalytic convertor collapses internally or becomes blocked, they have no effect on the performance of the car as such. If you do want to replace it then contact Keron he'll probably have loads of 2nd hand ones available. Quote Link to comment Share on other sites More sharing options...
Guest stubo sz Posted May 1, 2012 Share Posted May 1, 2012 my car is a jap import sz auto thanks for everyone help so i think ill just put a decat on .i take it you just take the sensor off and wont get any warnig lights Quote Link to comment Share on other sites More sharing options...
Nic Posted May 1, 2012 Share Posted May 1, 2012 Easiest thing to do is to tie up the temp sensor out of the way with a cable tie. Quote Link to comment Share on other sites More sharing options...
Guest stubo sz Posted May 1, 2012 Share Posted May 1, 2012 thanks for your help nic Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted May 19, 2012 Share Posted May 19, 2012 Easiest thing to do is to tie up the temp sensor out of the way with a cable tie. Make sure you don't cut it off as it will more than likely cause you to get warning lights, The guy at Austec just cable tied it above where it was and after 8k miles it has been fine like that. Quote Link to comment Share on other sites More sharing options...
