Blitz SBC II-iD
roboldham
OK
Basically (in my limited understanding)
Gain = % increase in spool up time over stock
Set = % increase in the boost above stock
Increase the gain too high and you get spike = bad
Increase set too high and you get over boost = bad
Channel setting can be used to dictate speed at which each setting comes into play (useful with Auto - not so with manual)
Scarmble - settings for higher boost settings for limited period of time
Settings that most people have is on said other list
Because of worries I had with overboost i now changed mine to reflect higher settings at lower speeds and reducing off with more speed - so I could still use kick down without it going into orbit!
You can download the instructions off the net - I think I posted link somewhere
VITAL that you set it up correctly - or can do damage - do not leave on auto mode
Cheers
Paul
