Looking to retro fit the active front spoiler
Josh42
I have all the parts and actually went to attemp it yesterday but the first bolt i touched on the offcoming undertray snapped (corrosion due to where its located, salt, rain etc) so i'll need something for removing severed bolts first.
I'll try mate just check you do have the wiring on your SZ already vast majority of cars do. It'll be lurking down below your drivers side headlight infront of the radiator. Small black plug. You might even see another smaller plug next to it. Its for a 2nd horn. The internal wiring will be behind stereo (large white plug for ECU and smaller black one for Spoiler switch)
You'll need:
The spoiler assembly
The spoiler ECU
The spoiler switch
The loom (it may be present already - see if you can check beforehand) or you'll need to make up a manual controller.
If you can get all the stuff and bring it over to Nantwich, I can help you fit it.
