Auto transmission fluid
rayg
Just been to the main dealer to get a spoonful of auto box oil, as it just needs a top up. Typical, they said they don't stock it and would have to order some (wonder what they do when they have to do a service) Whats more, it comes in a tin big enough to last a lifetime of top ups at £25 plus vat. My hand book says it needs Tll. Can I use any other ie. a typical halfords one. (I have a litre suitable for Fords in the garage)or must it be Tll, don't want to mess up. Does anyone else know where I can get something suitable around Manchester. Going to Chris Wilson's will cost more in petrol than getting some from the main dealer. Yet they piss me off. Any idea's
Yep, you need the toyota stuff, no other will do, and yes its £25+vat for 4 litres.. and yes, its TII rebranded and improved and now called T-IV... and no.. dont put anything else in.
Make sure they order you the *new* T-IV in the black and red can and not the old stuff.. it changed in May 2002.
Draining the auto box is actually a partial drain and it is not difficult. Do a search and you should find quite a few discussions on this. It is a good idea to measure the amount of fluid taken out then replace that amount, run the box warm and do the selector routine then top up. That way there is no risk of running the box with the fluid too low.
You may have problem ordering the fluid from some dealers as it may be down as a Lexus part. My local would/could not get it.
Hi Chase, nice to know that there are others with supras in the area. I also live about 10 mins from the Trafford centre. Yes I use RRG at Salford. If you need any parts ask for Dave Cook in the stores and mention me and he will give you between 10-20% discount for anyone from this club. Don't know about import parts though) I have a bill for a new headlight (glass) from the previous owner for £409 fitted. Dave got me one for just over £100. I asked the mechanics how to fit it and they said ohh... you have to take the front end apart, its a messy job. I thought bugger and posted here. Back came the replies...undo 3 bolts, 20 minutes and sure enough. Forget any kind of mechanical work but Dave will order you the parts fast and cheap. Where are you getting your beasty from? What colour.
All the best
Hi Ray,
That discount sounds really good :)
I'm getting a completely standard silver 94 GZ (pic on avatar) - It's being imported by Paul Whiffin and should be landing this Friday !!
So I should be picking it up off him in a few weeks after it's been SVA'd.
Cheers
