antno Posted April 27, 2012 Share Posted April 27, 2012 hi car has been stood since November when i bought it, previously it was in japan and don't know what use it has seen. im planning driving to lemans in June and would like to know if there are and common problems with pipes that have gone hard and split or just anything in general. im gunna throw a belt at it and tensioner and that next week, also cam gaskets,plugs aux belt, going to check all the brakes and lines, torque all the sub frame bolts. check all fluids and generally spanner check the rest of the car. just wondering if there is anything that is a pain in the arse to get to at the side of the road that i could do with looking at while i have a chance. im gunna try and put some miles on it to see if anything shits itself but it would be nice to catch it before. cheers antno Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 27, 2012 Share Posted April 27, 2012 (edited) The brake calipers would be on top of my list, make sure the pistons move freely and if you have the sliding caliper type i'd check they move freely too. If your changing the plugs i'd get some new coil pack connectors as these can fall apart. I'd also get the 2 hoses that go between the cam covers as they go rock hard and you'll need to remove these to help lift off the coilpacks when you change the plugs Edited April 27, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
antno Posted April 27, 2012 Author Share Posted April 27, 2012 The brake calipers would be on top of my list, make sure the pistons move freely and if you have the sliding caliper type i'd check they move freely too. sorry forgot to say its a 1996 bpu tt6 j spec with big brakes all round. brakes were fine when i parked it but will be stripping and checking them and lubricating them back up. cheers pal Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 27, 2012 Share Posted April 27, 2012 (edited) Its well worth replacing the outer seals on the calipers as they perrish and split letting in water etc which results in seized pistons, refurb kits are approx £60 to do the fronts and the same for the rears. It'll save you costly repairs in the future Call Steve Manley for any genuine Toyota parts, he's at Inchcape Toyota in Oxford 01865 291333 Edited April 27, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
antno Posted April 27, 2012 Author Share Posted April 27, 2012 Its well worth replacing the outer seals on the calipers as they perrish and split letting in water etc which results in seized pistons, refurb kits are approx £60 to do the fronts and the same for the rears. It'll save you costly repairs in the future Call Steve Manley for any genuine Toyota parts, he's at Inchcape Toyota in Oxford 01865 291333 cheers pal. ye i deal with Steve usually, the company i work for has an account there. Quote Link to comment Share on other sites More sharing options...
