DARETT Posted April 27, 2012 Share Posted April 27, 2012 I'm looking to change my head/cam combination soon, so am putting this up to make way. This is an amazing head which did not have any restrictions even at 1300hp. The head was built with spool and power in mind. I have used it in conjunction with a 600hp setup as well as my current one, and it performed flawlessly on all platforms. The head is based upon the Whifbitz Stage 4 race head. It's then been further ported and had valve work done to ensure more power all over the rev range. It's helped to make 36psi of boost by 5krpm! The head consists of the below: Ferrea 1mm Oversize Valves Ferrea Valve guide seals Ferrea bronze valve guides Supertech Double valve Spring Supertech Retainers Supertech Locators Extensive porting to maximise flow and spool 1/2" Stud conversion JUN 272 Cams ARP 1/2" Studs This head to get to this spec would cost in the region of £5k+ depending on where you get it from. It's comparable to the Titan stage 5 head which is $10k This is a bargain for anyone wanting an awesome head SOlD Link to comment Share on other sites More sharing options...
mrgee2jz Posted April 27, 2012 Share Posted April 27, 2012 would you take offers??? Link to comment Share on other sites More sharing options...
DARETT Posted April 27, 2012 Author Share Posted April 27, 2012 I'd take an offer of your car Link to comment Share on other sites More sharing options...
