dive_popo Posted April 27, 2012 Share Posted April 27, 2012 Hi, I'm looking for a field harness (extension harness) as I'm installing a piggyback I dont want to cut the stock loom Found one on ebay, but its amazingly expensive for a piece of plastic and few cables ! So thought that maybe someone of you have one and dont use it anymore Thanks, Peter Link to comment Share on other sites More sharing options...
Pixelfill Posted April 29, 2012 Share Posted April 29, 2012 I got mine from autosport wiring via MVP. They are not cheap pieces of kit, given that the connectors are only available from one supplier - who paid for the production line to be restarted. and the number of individual connections which are hand soldered. the quality is worth paying for, the alternative is to hack your loom and solder the connections yourself in the footwell. Any second hand Field's harness is likely to have already been hacked. Mike Link to comment Share on other sites More sharing options...
Wez Posted April 30, 2012 Share Posted April 30, 2012 Speak to RyanG Link to comment Share on other sites More sharing options...
dive_popo Posted April 30, 2012 Author Share Posted April 30, 2012 Thanks guys Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 30, 2012 Share Posted April 30, 2012 Do what I did, Buy a cheap NA ecu for £20 and get your hot air gun out and de-solder the connector. Getting the plugs is not so easy but if you are making a stand alone ecu converter then you don't need them. Lyndon. Link to comment Share on other sites More sharing options...
dive_popo Posted April 30, 2012 Author Share Posted April 30, 2012 Do what I did, Buy a cheap NA ecu for £20 and get your hot air gun out and de-solder the connector. Getting the plugs is not so easy but if you are making a stand alone ecu converter then you don't need them. Lyndon. Thanks, good point ! But I'm going for a piggyback, and need an extensions as I dont want to cut my stock loom... Link to comment Share on other sites More sharing options...
