Samurai 20V Posted April 27, 2012 Share Posted April 27, 2012 Hi Chaps. I got my Supra relicenced and back on the road, it has been giving me some issues to start when cold. The car is full BPU on stock ecu, fuel pump is walboro. It cranks for at least 10secs or so before it starts, at times it only starts on the 2nd go. When it starts there is a some of blue smoke, but it clears up quickly. It was parked for 2 months, in which time the battery died, I had it recharged. I did a search here, there were some threads that led to a stuffed water temp sensor, but I still uncertain on the cause. When the car is warm it starts on the turn. There is no smoke whilst driving, occasion puff when idling hot (turbo seals). Any other advice on a potential solution? I am worried that the compression may be down, but the car feels awesome to drive, am I jumping the gun? Thanks. Quote Link to comment Share on other sites More sharing options...
Soopra Posted April 27, 2012 Share Posted April 27, 2012 Valve stem seals? Quote Link to comment Share on other sites More sharing options...
Geo Posted April 27, 2012 Share Posted April 27, 2012 steam seals wont make it hard to start, that will give you the blue smoke syndrome. Have you tried starting her with jump leads on? Could be a duff battery not supplying enough juice to start her? Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted April 27, 2012 Author Share Posted April 27, 2012 steam seals wont make it hard to start, that will give you the blue smoke syndrome. Have you tried starting her with jump leads on? Could be a duff battery not supplying enough juice to start her? Not yet, the battery was replaced last year, although it has died twice since I fitted it... (1st time when I ran the amp on for too long, 2nd while it was parked off). Batterys are bloody big bucks here, I just fitted the cheapest one. The car had a larger battery fitted, I changed for the stock size to fit the coolant bottle from the FMIC kit.. Will have to investigate the battery side of things before making any rash decisions. Thks Geo. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted April 27, 2012 Author Share Posted April 27, 2012 Valve stem seals? I reckon they are stuffed, but as Geo said, should not caused hard starting.. Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted April 27, 2012 Share Posted April 27, 2012 If the battery has died the ECU will have reset. If I disconnect the battery the idle can be a bit low leading to stalling until it re learns "stuff". After 5 - 10 miles all is well again. If the battery is good a quick blast might be worth a try. Quote Link to comment Share on other sites More sharing options...
