1st decat cut and weld?
listy
I have the piece of the old decat pipe which attatches to the downpipe, and I managed to order the wrong decat pipe from whifbitz (i know i know) who aren't open again until the 30th (according to the answer phone). Would it be ok, to cut the new decat pipe and weld the old end onto it, so it fits? It will be getting done professionally, by a garage, who seem to think it will be fine.
Im only doing this as I really dont have the time to wait til the 30th and get the pipe swapped.
What are peoples take on this?
(Quick responses required as I'm taking the car to paint and have the exhaust welded in about 40 mins!!!)
If you need it now then you have no choice. I vote yes if you trust the garage to get it lined up exactly as this could throw your entire exhaust on the wonk. As a couple of mm out of line at the front can make your system an inch or two too high/low
Fast enough? I'll try harder next time.
If you don't mind 3 points and a £60 fine then I vote yes to that as well.
On a serious note I'm not sure that is a great idea, an awful lot of sparks and heat are emitted from having no exhaust. It would also depend on what sort of roads you are planning on driving.
disclaimer: I know nothing so don't listen to me.
Main road, not often patrolled though. The police are pretty good around here, and they already know about the incident with the white van, so may be sympathetic (I hope) again, i dont really have a lot of choice tbh. The fix and spray is using pretty much all the funds from the in laws, and dont have the money to get it transported to the garage
It'll be fine (welding the cat up so it fits), as for driving without an exhaust, you will attract alot of attention to yourself, hopefully you will get lucky :)
I was lucky lol not a police car in sight. Realised just before I left that no exhaust meant no restrictor ring, so just drove off boost to be safe.
Car is no at the workshop for the body work and paint! :)
They are trying to get it turned around asap so I have time to do the bits i want for japfest, maybe as soon as the end of next week, so all is good :)
