A question for the guys running V8s...
J-Meiser
Hi
I have read that it is possible to replace the distributor/HT lead setup on the 1UZ for a coil-on-plug setup. I have browsed numerous forums but I cannot seem to find a definitive answer or straightforward guidance (and I don't really want to sign up to even more forums - I've lost track of how many I have signed up to over the years), so I figured I would ask those who have done it on here :thumbs:.
My questions are - how difficult is it to make this conversion work? Which coil packs would you recommend? Do you have to use an aftermarket ECU or can you make it work with the standard one?
Thanks in advance!
You need the 1UZ coil on plug coils (2uz and 3uz VVTi ones should/might also work). It's the bore size of the plug holes you have to make sure is correct which is why I couldn't recommend 1ZZ-FE coils, however, 2ZZ-GE coils might work as they are thinner. These are all internally amplified so no igniter required. You will need a ecu with at least 4 ignition drives like a Syvecs, MoTec, Emerald K6 or Link G4 to make it work (or some very clever multiplexor that uses the engine position sensors to redistribute the ignition signal from the OEM ecu to the correct coil).
Lyndon.
You need an ECU that can give 8 outputs instead of 2. I wouldn't of thought your ECU can do that, otherwise you would have CoP in the first place.
The 2ZJGE is the same. If you have a cam sensor and crank sensor you can send these signals to the aftermarket ECU which can control the other seperate coils.
You need a Map ECU to convert the system.
I'm a werther's originals man myself. :D
Lyndon.
Skittles for me ;)
Thanks Nodalmighty and Noz - it looks like I'll leave that idea on the back burner for the time being. I want to get the engine tidied and rebuild and I figured it might me something I could do whilst I had the engine on the stand, but, as I feared, it is going to require more knowledge and funding than I currently posses :(
I'm in two minds as to V8 or NA-T. V8 would be cheaper, but NA-T easier.
V8 sounds nice, but then so does a 2JZ on full song.
As I was involved in probably the first 1UZ-FE V8 Supra conversion in the UK when I was at Thor I should give the NA-T a go as that's something I've not done before.
Lyndon.
Lyndon.
3UZ-FE maybe? :think:
You can pick up a V8 Aristo for around £250.
Surely you want the SC400 as the sump and engine mounts are in the right place to start with?
I'm sure there is a 4x4 GS V8 which might give someone ideas.
You're not likely to find many Lexus SC400s in the UK... on the other hand, there are plenty of V8 Toyota Soarers. :)
The V8 Aristo is 4WD (and if you see one for £250 let me know).
You ideally need an ECU with fully sequential spark and injection, as said above the extra heat from running it wasted spark will cook the coils, I've learn't that the hard way.
Get yourself a Megasquirt MS3X, I'm currently supplying and fitting them if you need any help or advice, it's the only reasonably priced ecu that can do the job properly.
Ben
Ben
I'd forgotten all about Megasquirt, I may have to look into this - after I sort out some newly-discovered problems. My Soarer will no longer start and is stuck in 'Park' :(. So until I get these sorted, my conversion plans are on hold!
Drop me a pm with your number if you're still having trouble with it.
Thanks and will do. I'm aiming to have another look at it next weekend, as this weekend's weather shot down my plans. I'll let you know what I try out and how I get on :thumbs:
