JMB Posted April 26, 2012 Share Posted April 26, 2012 Hi all, I just order U.R. Lightweight Pulley kit (except crank but including idler pulley). I wonder what torque install those ? Didn't t find out yet ! Thanks all Quote Link to comment Share on other sites More sharing options...
Nic Posted April 26, 2012 Share Posted April 26, 2012 You should find the answer in here http://www.turbosupras.com/pages/en/pages/specifications/JZA80/a80tsrm.htm Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 26, 2012 Share Posted April 26, 2012 Best to find out and post them up here for the future... Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 26, 2012 Share Posted April 26, 2012 Everythings in the WSM, you only have to look Quote Link to comment Share on other sites More sharing options...
JMB Posted April 27, 2012 Author Share Posted April 27, 2012 So! For the alternator pulley : 4. INSTALL PULLEY (a) Install the pulley to the rotor shaft by tightening the pulley nut by hand. (b) Hold SST (A) with a torque wrench, and tighten SST (B) clockwise to the specified torque. SST 09820–63010 Torque: 39 N·m (400 kgf·cm, 29 ft·lbf) © Check that SST (A) is secured to the pulley shaft. (d) Mount SST © in a vise. (e) Insert SST (B) into SST ©, and attach the pulley nut to SST ©. (f) To torque the pulley nut, turn SST (A) in the direction shown in the illustration. Torque: 110.5 N·m (1,125 kgf·cm, 81 ft·lbf) (g) Remove the generator from SST ©. Quote Link to comment Share on other sites More sharing options...
JMB Posted April 27, 2012 Author Share Posted April 27, 2012 Power steering pulley . 2JZ–GTE: INSTALL SUCTION PORT UNION (a) Coat a new O–ring with power steering fluid and install it to the union. (b) Torque the bolt. Torque: 13 N·m (130 kgf·cm, 9 ft·lbf) Quote Link to comment Share on other sites More sharing options...
JMB Posted April 27, 2012 Author Share Posted April 27, 2012 . 2JZ–GTE: INSTALL VANE PUMP PULLEY Using SST to stop the pulley rotating, torque the nut. SST 09960–10010 (09962–01000, 09663–01000) Torque: 43 N·m (440 kgf·cm, 32 ft·lbf) Quote Link to comment Share on other sites More sharing options...
